You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2140) beta English
Posted by: pspad | Date: 2005-10-30 19:18 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.0 (2139)
News
rewrited Insert text to lines (Alt+I) function. You can insert begin and end of the text at once now
the running time information added at the end of the compiler LOG
new Korean localization added (Shin Ryu)
speed optimalizations - Search/Replace and Reformat HTML
Corrections
store user spell dictionaries into user profile
option Wrap with right edge works again
corrected internal conversion table - ANSI - ISO-8859-2
exception if PSPad starts with parameters binary file + line number
exception if code page different from ANSI and 0 bytes file size
problem with the active Scroll past EOL option and the Sort function
the C++ Code Explorer and compiler defines
add word to spell disctionary exception
Jan
Posted by: PJJ | Date: 2005-10-30 21:58 | IP: IP Logged
Wow! The same file (213 KB), the same conditions as previously (S&R , --> %, ca. 2500x) now took approx. 10 sec (with highlighter on and word-wrap off), compared to 45 sec with previous build. You're great!
Posted by: Bartlomiej Dwornik | Date: 2005-10-31 08:56 | IP: IP Logged
Still don't work properly:
Right after PSPad start all key shortcuts are working correctly (Ctrl+B for <b></b>, Shift+Ctrl+Space for nbsp , Ctrl+Enter for <br>, etc.) But after a while, especially when active window is changed or open new file shortcuts don't work anymore.
I have to restart PSPad to make them work again.
But recently I noticed, that shortcut Ctrl+Alt+U (defined for change letters form lowercase to uppercase) works everytime, even if else (Ctrl+B, Shift+Ctrl+Space, Ctrl+Enter) stop work.
Post Edited (10-31-2005 09:56)
Posted by: pspad | Date: 2005-10-31 09:16 | IP: IP Logged
Sorry, but I didn't write that it's corrected. You see it somewhere in the description ?
I know, its serious problem and I will correct it as soon as I will be able.
Posted by: Bartlomiej Dwornik | Date: 2005-10-31 09:32 | IP: IP Logged
Sure, You're right
I wrote it just to remember about it. Please don't be angry.
Posted by: ShiLong | Date: 2005-10-31 15:23 | IP: IP Logged
Switching between PHP and XHTML files will cause an void error, the highlighter forget his clip file. The shortcuts like CRTL+RETURN wont run correctly after this. if i choose an othern highlighter and switch back it will work correctly.
greetings,
ShiLong
Posted by: Jody | Date: 2005-10-31 22:52 | IP: IP Logged
With word wrap on text does not show except on the first line.
Toggle it off and text appears.
Toggle it on and text disappears.
The first line of text remains visable.
Tried different fonts so I don't think that's it.
This is an update to the above.
I turned off "Wrap (soft) with Right Edge" in user settings.
Word Wrap still enabled in "config" and "special settings" from "Direct Edit"
and now it works as it should.
Post Edited (11-01-2005 03:10)
Posted by: pspad | Date: 2005-11-01 04:19 | IP: IP Logged
Send me example of text. Used highlighter ?
Posted by: Joe Belmaati | Date: 2005-11-01 06:56 | IP: IP Logged
Thank you very much for including script execution time :D
Sincerely,
Joe Belmaati
Copenhagen Denmark
Posted by: nfree | Date: 2005-11-01 10:55 | IP: IP Logged
I'm very glad with Korean localization . . .
