You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2139) beta English
Posted by: Dwornik | Date: 2005-10-24 13:43 | IP: IP Logged
After Ctrl+Space ClipShow is appeared (as is defined in KeyMap.INI) and shortcuts still don't work.
Posted by: DxGx | Date: 2005-10-24 15:07 | IP: IP Logged
great features!!!
however new feature with FTP drop down menu shows random list of existing FTP accounts. It seems that list just needs sort or something .
I agree with jhon that SSH for FTP would be great! lol
Posted by: Eemeli | Date: 2005-10-24 16:06 | IP: IP Logged
Yeah, we want SSH support. Please, Jan, make that.
Posted by: Nomad | Date: 2005-10-24 17:49 | IP: IP Logged
quote by Jan:
>> Ctrl+Space doesn't reset shortcuts ?
Well, sometimes involking the Cliplist solves the problem, sometimes a PSPad restart is necessary.
I'm using almost always the multi-Highlighter and observed that -sometimes- the shortcuts don't work anymore after editing some PHP code and then returning to the HTML section of my document. Maybe that in some cases the Shortcuts aren't properly re-set to the according Multi-highlighter section?
Posted by: Bartlomiej Dwornik | Date: 2005-10-25 07:39 | IP: IP Logged
As for Nomad's suggestions about shortcuts and multi-highliter
I decidet to test it, and thats what I have done:
- set that default new open file is html in multihighliter mode
- restart PSPad
- in new file, opened right after start all shortcuts works right
- when I open new, empty file with ICON - in new file (.html) shortcuts don't work
- but when I open new file with Ctrl+N and select HTML from type list shortcuts work!
- when I open any of my .asp, .php, inc or even .html files from HD, shortcuts don't work
Same situation was when I changed default settings to open html file in html mode and turned off html-multihighliter. Nothing changed in PSPad behaviour.
@Nomad - can You check is Your PSPad's behaviour similar?
@Jan - do You have any idea what could it be? If it is not common problem, maybe we had messed config files somehow?
Posted by: Nomad | Date: 2005-10-25 11:10 | IP: IP Logged
Hi Bartlomiej,
I tested as you suggested, and even when:
my shortcuts don't work. Tested the same with the setting 'default new file in TXT format', and nothing changed. So I'm still unsure what exactly is the reason for this annoyance...
Posted by: Mario Molinari | Date: 2005-10-26 08:29 | IP: IP Logged
Jan,
I am not sure whether this problem is just mine, but, when editing a C file with the Unicode version, I occasionally see additional strange symbol after the slash ("/") character at the end of a comment. It might be that the problem only shows up if the slash is at the end of a line as well, but I'm not sure about this.
The most common symbol is a sign similar to the vertical bar (|) character, but shorter and thicker, other times I see a comma (,). In most cases everything is Ok, though, but if you scroll a large file, it is almost sure that you'll see something strange here and there.
Sometimes, you don't see anything, but, if you select the text, the strange symbol appears in reversed selection.
The file is Unix text.
I guess that syntax highlighting may have something to do with this problem.
As far as I can say, the problem has always been present in release 4.5.0.
Maybe you could check the problem against some of the sample source files I sent you in the past, otherwise I can send you a new one, if needed.
This is an aesthetic problem, but rather annoying.
Thanks for your attention, cheers.
Mario
Posted by: Bart | Date: 2005-10-27 11:34 | IP: IP Logged
Jep, SFTP support would be cool!
Posted by: Mario Molinari | Date: 2005-10-27 14:24 | IP: IP Logged
Some supplemental information about the problem reported.
It seems that the problem sometimes (but not always) disappears by scrolling in and out (i.e., up and down) of a piece of code, where it is present.
Another problem about the C code explorer window.
It seems that the C/C++ reserved keyword "defined" (used by C pre-processor) is mislooked as a function name.
For example, the line
#if defined(LINUX) || defined(PSOS)
appears as a function definition in the code explorer docked window.
Ciao,
Mario
Posted by: rem | Date: 2005-10-27 20:53 | IP: IP Logged
>>>- but when I open new file with Ctrl+N and select HTML from type list shortcuts >work!
>my shortcuts don't work. Tested the same with the setting 'default new file in TXT >format', and nothing changed. So I'm still unsure what exactly is the reason for this >annoyance...
I've been crying about this issue for so long and I after a while I gave up... Same here with this shortcut trouble. I'm working with the HTML.DEF (multihighlighter default) open and when my shortcuts stop responding, I'm saving it to the same location and everything works fine until next time when I'm saving it again and so on ... might sound crazy but this is what's working for me.
thanks.
Post Edited (10-27-2005 23:30)
