You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2139) beta English
Goto Page: 1 2 3 4 Next
#1 PSPad UNICODE 4.5.0 (2139) beta English
Posted by: pspad | Date: 2005-10-22 21:02 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.0 (2134)
News
external applications and compiler setting - PSPad suggest you the application directory in default directory selection
Connect to FTP button - added dropdown menu with the existing FTP connection list
changed file type plugins. Read Readme.txt file in plugin directory. This is not a last plugin change. If you use plugins, please wait for the next build
added PASV command to keep FTP online
Tcl/Tk highlighter supports now TiX extension
added the system variable %FileName2% - returns file name without an extension
Corrections
small GUI correction - char '&' in hints e.t.c.
search in files - some options was disabled if different CP than ANSI
Swap lines function in no while lines was selected
EOL in UNICODE files depends of FileType (DOS/MAX/UNIX) setting in PSPad
Search in files and DBLClick on the binnary file in search result
window flicckers after reopen function (Ctrl+R)
ClipBoard monitor inserts 2 times texts coppied in PSPad
Insert text to lines function - insert text to position
Open copy (Ctrl+D) delete file after window was closed
problem with left gutter size when you create bookmark
PSPad handles changes of printers number during PSpad session
handled exception now if your e-mail client doesn't support SIMPLE MAPI interface
FTP client - refresh connect to FTP if disconnected
file without extension and highlighter detection
function Autrefresh doesn't work from Window menu
#2 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: Ilya | Date: 2005-10-23 06:18 | IP: IP Logged
Works ok on WinXP and Win98SE.
Thank you!
#3 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: Jume | Date: 2005-10-23 06:29 | IP: IP Logged
just saying that the swap lines works perfect again, yay! smiling smiley
and a little tiny thing that i think is easy to correct:
in php, with double quotes it does color this way, its not perfect but its good enough:
<a href="<?=$some_var*Some_function($some_parameter)?>">
but with single quotes...
<a href='<?=$some_var*Some_function($some_parameter)?>'>
i suppose that it is only needed to tell to the reg exp used for this to look for both double and single quotes, but who knows...
[edited]
wooo!! i was supposed to be the first post, took me so long to write, damnit!!
Post Edited (10-23-2005 08:31)
#4 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: Jume | Date: 2005-10-23 18:37 | IP: IP Logged
the menu option projects/open folder files is active by default, which i think is not a bug since pspad has always a project active
when new and empty project (either at start or choosing new project), hide the left panel where the project tree is, the option obviously remains active, but if you run it, instead of doing nothing (no files at all) it does an exception...
if you add files to the folders, and select any folder or the projects root then hide the panel, it opens the files then gets the exception
summarizing, the menu option projects/open folder files does give an exception anytime you have selected a folder or the projects root and the projects panel is hidden
#5 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: pspad | Date: 2005-10-23 19:11 | IP: IP Logged
> project active
The empty project mean the inactive project
Its a bug.
#6 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: MoMann | Date: 2005-10-23 19:12 | IP: IP Logged
Thanks for the Tix extensions. Works great.
MoMann
#7 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: jhon | Date: 2005-10-24 01:23 | IP: IP Logged
Hi! excute me!
Could Ftp suppot ssh ?? Tnanks!!
#8 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: Dwornik | Date: 2005-10-24 11:00 | IP: IP Logged
It was reported but still occurs:
Right after PSPad start all key shortcuts are working correctly (Ctrl+B for <b></b>, Shift+Ctrl+Space for nbsp , Ctrl+Enter for <br>, etc.) But after a while, especially:
- when I have to change active window, ex. for GIMP, and came back,
- I open new .php .inc .asp or .xml file
shortcuts don't work anymore. I have to restart PSPad to make them work again.
#9 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: Nomad | Date: 2005-10-24 12:36 | IP: IP Logged
I can confirm the behaviour Dwornik described above. Just after a while of working, the shortcuts don't work anymore. This occured already in Ver 4.3.3 on my machine (WinXP SP2) IIRC.
Post Edited (10-24-2005 14:36)
#10 Re: PSPad UNICODE 4.5.0 (2139) beta English
Posted by: pspad | Date: 2005-10-24 13:35 | IP: IP Logged
Ctrl+Space doesn't reset shortcuts ?
