You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2134) beta English
Posted by: pspad | Date: 2005-10-10 06:27 | IP: IP Logged
gosurfbrowser.com wrote:
> A request: Do not display the name of current tab in
> application's title. It's boring when I open pspad in office.
You are using WinXP 64bit, right ?
Go to Program settings / Direct edit
Set SimpleFileTabs=1
I don't know, why the standard Windows control doesn't support owner draw in 64 bit OS
> A bug-report: When I search a term in a large file (300kb,
> every line has about 300 chars), the unicode editor scrolls to
> result very very slow. (ANSI version doesn't have this problem)
> Is this unicode-synedit too instabile?
I will test it
Posted by: gosurfbrowser.com | Date: 2005-10-11 09:36 | IP: IP Logged
I'm using a normal WinXP+SP1 (2x XEON). It's a quite powerful desktop.
- 2x XEON 2.2GHz
- 1GB DDR2
- ATI Fire GL4
- 320GB SATA-RAID
I've added "SimpleFileTabs=1" under "pspad.ini" > "[config]". But the same result. This means: when I minimize pspad, the application's title (in taskbar) shows the current openen document not the text "PSPad".
Is this version of SynEdit not stabile? I suppose, they have changed a lot of things. I still prefer the ANSI version of PSPad
getgosurf.com
Posted by: DJ N-4ceR | Date: 2005-10-11 18:48 | IP: IP Logged
Auto-Indent:
Is it possible to un/indent a whole block without marking that lines and to indent with (shift) tab?
Posted by: pspad | Date: 2005-10-11 19:09 | IP: IP Logged
You must mark what you want to indent. PSPad doesn't know it.
Posted by: MoMann | Date: 2005-10-11 20:38 | IP: IP Logged
Jana,
it appears that "tolower" and "toupper" hightlights ae not recongnized in tcl/tk
thanks,
Momann
Posted by: MoMann | Date: 2005-10-11 20:43 | IP: IP Logged
Nevermind, my error on syntax on toupper and tolower
Momann
Posted by: Fred | Date: 2005-10-12 12:10 | IP: IP Logged
If it can help to found the bug with key map.
I just test it, and the "resetting key map" operation resolve the bug.
Then I realized that now I have the correct "code page" when I open document so all special caractere are ok. (before, It never found ansi doc's)
Just Great, I'am waiting for the last version !!!
Fred
Posted by: Triplex | Date: 2005-10-12 20:25 | IP: IP Logged
>It's no problem to change it.
PSPad will use the line separator depending on File format (Dos/Unix/Mac) from the next build in UNICODE files too.
PSPad now use the standard WideLineSeparator in UNICODE files.<
Sorry for the delay. I have re-installed PSpad 4.33.2085 to solve the Unicode line break issue.
Do you mean this issue (NotePad sees squares boxes instead of line breaks) will be solved in release later than 4.50.2134? Or is there any easy way to fix this in the current version?
Posted by: pspad | Date: 2005-10-12 21:33 | IP: IP Logged
This problem is already solved. Solution for you will be available in the next 4.5.0 build
Posted by: Dwornik | Date: 2005-10-13 08:29 | IP: IP Logged
I can not find anything about my problem, so I decided to write:
I work on .php .html .inc .asp and .xml files. Right after PSPad start all key shortcuts are working correctly (Ctrl+B for <b></b>, Shift+Ctrl+Space for , Ctrl+Enter for <br>, etc.) But after a while, especially when I have to change active window, ex. for GIMP, and came back, shortcuts don't work anymore. I have to restart PSPad to make them work again.
Perhaps problem is in not in program, but in my config files? Does anybody came across similar thing?
