You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2134) beta English
Posted by: pspad | Date: 2005-10-05 19:49 | IP: IP Logged
Download link: pspad.cincura.net (1.5 MB)
Changes to 4.5.0 (2133)
News
Close All function added into file tab context menu
Corrections
Find in files - search in the ANSI files
dblclick to select a word in the highlighters: SQL, CSS, Perl, Cobol
Code explorer for Perl and the hash variables/strings
negative numbers in the CSS highlighter
the PSPad freeze problem during clip insert
Posted by: Lolo | Date: 2005-10-05 21:30 | IP: IP Logged
You did not correct the following bug I already sent you
Here is the way to reproduce it:
- Create a file names like that: xxx.exe.txt (xxx is what you want)
- Copy it on a folder with spaces inside its name
- Now, Open PSPad with an empty file
- Then double click on the file you have just created
PSPad open as much as new files than number of spaces (minus one) in the name of the folder and dots contain in the name of the file
Example:
if the file is created in C:\Forlder For Testing PSPad\test with space.exe.txt
PSPad open files names: Folder, For, Testing, test, with, space.exe.txt (5 files)
More PSPad does not display the content of the opened file.
Funny, isn't it?
For information, this problem does not appear if you make the file drag and drop directly into PSPad or if you open this file in first (if PSPad is not already started)
It is not a serious bug but it is a bug
Thanks and have a nice.
Posted by: pspad | Date: 2005-10-05 21:39 | IP: IP Logged
I know it. This bug still wait in my mailbox as hundreds of the other bugs and requests
Posted by: Donius | Date: 2005-10-06 12:42 | IP: IP Logged
I know that you knew this already from the message-box testing that i missed out on ((damn this day job!)), but the clips problem is fixed. Thank you for yet another in a string of quick releases. You have made my day.
-Brendan
Posted by: Jume | Date: 2005-10-07 00:01 | IP: IP Logged
found a lil highlighter bug in css :
the values that has numbers inside (e.g. -20px, 13pt, 5em...) are colored wrongly when the number is only 1 digit (e.g. 3ex, 2px, 0pt...)
it is correct when 2 or more digits and if a negative sign is before a one-digit one
summarizing:
correct highlighting : 10px, -2pt...
incorrect highlighting : 1px, 0pt, 3em...
Posted by: Chris Pirillo | Date: 2005-10-07 06:59 | IP: IP Logged
With English set as my default language, when opening up the Program Settings dialog, the initial header for the Language settings reads "Jazyk" - and I'm not sure what that means?
Posted by: Chris Pirillo | Date: 2005-10-07 07:20 | IP: IP Logged
When selecting a Menu item (or pressing the ALT key), the Status Bar hint includes the ampersand within it.
Posted by: Faterson | Date: 2005-10-07 07:26 | IP: IP Logged
"With English set as my default language, when opening up the Program Settings dialog, the initial header for the Language settings reads "Jazyk" - and I'm not sure what that means?"
"Jazyk" means "Language" in Czech. Are you THE Chris Pirillo? 8-)
Posted by: Fred | Date: 2005-10-07 09:01 | IP: IP Logged
Just trying your editor, download and install last version, now beta version (this one)
BUT ALWAYS the same bug :
I can't use all the special keys (enter, dir, home, del, page up; down, insert, backspace, ..)
Can you solve the problem !?
help Please !!!
Thanks in advance
Posted by: Lolo | Date: 2005-10-07 11:42 | IP: IP Logged
I have found a bug with "Clipboard monitor window"
It seems that Copy button does not work correctly.
Here is the way to reproduce the bug:
Open the Clipboard monitor window (Alt+M)
Select a piece of texte or a word
Hit Ctrl+C or Click on the button copy on the main toolbar => The selected text is copied two times
Now, I don't know if it is normal or not. Select another piece of text an click on the copy button of the toolbar of the Clipboard monitor window. It add the previous text you have copied instead of the selected text. Is it normal?
For information, this bug has been introduced since the version 4.5.0 build 2133
Also, is it normal that PSPad catch all occurence of Ctrl+C even if you are in Word or any software and add the text you have just copied?
To finish with "Clipboard monitor window", why do you insert a carriage return when you paste text from "Clipboard monitor window" at the cursor position?
Otherwise, probably a stupid question but is it possible to keep windows like "Color selector window" or ASCII table window" opened when you restart PSPad?
I didn't found the corresponding option.
Thanks, see you soon and have a nice day
