You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2133) beta English
Posted by: pspad | Date: 2005-10-03 20:40 | IP: IP Logged
I am understand, but I havn't problem you describe.
WinXP, SP2, Pentium M, 512 MB RAM
Please all people with this problem, send me your PSPad.INI.
I will try to find some common points.
Posted by: TimV | Date: 2005-10-03 21:14 | IP: IP Logged
100% cpu & freeze confirmed
XP Home SP2, AMD 2.2Ghz, 1Gb RAM
It worked even after I deleted the PSPad.INI file.
Posted by: Markus | Date: 2005-10-03 21:19 | IP: IP Logged
I can confirm gogogadgetscotts problem with the new build. PC configuration: P4 2.6 GHz, 512 MB RAM, Win XP Prof. SP2
Reverting back to build 2132 until this is fixed.
Posted by: Pim | Date: 2005-10-03 21:35 | IP: IP Logged
I also have freezes after using clips
using a combo box whithout a default value which is left empty causes the crash
Pim.
Posted by: flow | Date: 2005-10-03 22:03 | IP: IP Logged
Ok, confirmed. When WordWrap is On the exception is there...
Posted by: pspad | Date: 2005-10-04 04:35 | IP: IP Logged
Please send me your problematic PSPad.INI file
Posted by: Lolo | Date: 2005-10-04 07:09 | IP: IP Logged
I am not sure that the solution is inside the PSPad.ini
I delete my PSPad.ini file and retry the clip test. PSPad freeze all the same.
Posted by: pspad | Date: 2005-10-04 07:25 | IP: IP Logged
I think too.
I tried PSPad.INI from you, Remus Boara, PIM without any problem
Do you use some windows skinning soft or something else, e.g. virtual desktops or... ?
What mouse and mouse driver do you use ? Genius ?
Posted by: Lolo | Date: 2005-10-04 08:36 | IP: IP Logged
I don't use any windows skinning soft or something else.
I have Windows 2000 sp4 and I use a Microsoft Wheel Mouse Optical with Mouse Suite driver (provided by Microsoft on a CD)
Posted by: Pim | Date: 2005-10-04 12:00 | IP: IP Logged
Up to build 2127 I have no problems. I've tested also on another computer.
I did not have build 2131 but starting with build 2132 same problem on both computers.
Both are windows XP professional sp2, no skinning or what so ever. mousedriver standard microsoft. mouse is also a standard 3 button mouse.
As test I have used the a tag clip in the multihighlighter. When I fill in all fields there is no problem but for example filling in only the href field then PSPad freezes.
