You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2133) beta English
Goto Page: 1 2 3 4 5 Next
#1 PSPad UNICODE 4.5.0 (2133) beta English
Posted by: pspad | Date: 10/02/2005 20:57 | IP: IP Logged
Download link: pspad.cincura.net (1.5 MB)
this CAB archive contains PSPad.EXE and language files only. Replace existing files from last full release
Changes to 4.5.0 (2132)
Correction
a filename on the file tab wasn't visible if file has extension only and file extensions was hidden in the program settings
solved problem with Editor keys
clip shortcuts are restored after Ctrl+Space
open file from internet
Find in Files function in UNICODE files
#2 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: Ublis | Date: 10/02/2005 22:20 | IP: IP Logged
Thanks, the editor keys are better now. Actually, they still disappear from the settings when you click Cancel as described in my previous post (http://forum.pspad.com/read.php?f=6&i=2662&t=2596#reply_2662), which is a bit ugly, but at least they come back automatically after restarting.
#3 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: Lolo | Date: 10/03/2005 08:57 | IP: IP Logged
Thanks a lot for this new release.
There is still the following problem:
In Xhtml Multi Highlighter, if i use any clips in the XHTML sections, PSPad takes up 100% of cpu.
Here is how to reproduce the problem.
- Open PSPad with an empty file and change document syntax highlight to xhtml.
- Now hit Ctrl+Space and type s
- Select samp
- To finish, simply clic the OK button (without typing anything in clip window)
PSPad freeze sad smiley
#4 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: pspad | Date: 10/03/2005 09:13 | IP: IP Logged
I am sorry, but I am not able to reproduce it.
I know, you send it to build 2132 too.
Maybe somebody can confirm your problem and we will be able to find some dependencies.
#5 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: Ilya | Date: 10/03/2005 09:38 | IP: IP Logged
I can confirm Lolo's problem.
PC's details (if it can help) : P4, WinXP Prof. SP2, 512 MB
Ilya.
#6 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: Thomas | Date: 10/03/2005 10:53 | IP: IP Logged
I can confirm Lolo's problem as well. Happens with any clip where you can add attributes as far as I can tell (checked HTML and XML as wel)
Win2000 with ATI Graphics card
#7 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: Donius | Date: 10/03/2005 15:07 | IP: IP Logged
I can confirm Lolo's problem with the new build as well. My PC Specs are the same as Ilya's.
- Brendan
#8 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: rem | Date: 10/03/2005 15:37 | IP: IP Logged
I confirm it too.. WinXP Pro SP2, AMD 2500+ 1G RAM
HTML works fine. The XHTML highlighter instead is taken up to 99% of cpu resources and freeze.
#9 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: octane | Date: 10/03/2005 15:54 | IP: IP Logged
Following problem:
- Open a new Document (Strg + N, Textfile)
- Press POS1-Button on your Keyboard
- > "Array out of Bounds"-Error in:
[004EB315] SynEdit.LastCharInRow (Line 8930, "SynEdit.pas" + 2) + $11
A bug. smiling smiley
mfg
octane
#10 Re: PSPad UNICODE 4.5.0 (2133) beta English
Posted by: pspad | Date: 10/03/2005 16:42 | IP: IP Logged
What is it POS1-Button ?
