You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2132) beta English
Posted by: rem | Date: 2005-09-28 20:33 | IP: IP Logged
pspad wrote:
> I hope in next build it will be OK
I know it will be ok. Everytime does. PSPad is great no matter what...
Posted by: pspad | Date: 2005-09-28 20:53 | IP: IP Logged
I found the bug!
I hope next build removes problem "keys doesn't work in editor window"
Posted by: rem | Date: 2005-09-28 21:02 | IP: IP Logged
I told ya... I knew it, I knew it... can't wait next release...
Posted by: Coditor | Date: 2005-09-29 13:21 | IP: IP Logged
I just installed this version to fix character encoding issues and am extremely happy that I can go back to PSPAD (had to switch to DW for some files).
I found something after I installed this version though, and this seems to be the best place to post it. The whitespace between characters (not lines) seems to have increased (compared with the previous version, 4.3.3 build 2092). I used Lucida Console but have switch now to Courier New because of that whitespace. Not an urgent matter since it has no impact on my code, but still something worth mentioning (and fixing )
Posted by: JCurtis | Date: 2005-09-29 13:52 | IP: IP Logged
Will it be possible to use a compiler on a remote host?
Posted by: JCurtis | Date: 2005-09-29 13:59 | IP: IP Logged
And one more thing. I used multihighlighter to write a script which creates a string that contains a javascript code. The highlighting was wrong. Try it yourself:
<script>
var str = '<script src="js.js"></script>';
</script>
Posted by: Lolo | Date: 2005-09-29 14:37 | IP: IP Logged
Hello JCurtis,
What's wrong exactly with the highlighting?
I test it and I don't have problem.
Posted by: Coditor | Date: 2005-09-29 14:44 | IP: IP Logged
I tested it and with the multihighlighter, the first </script> (inside the string) closes the first <script> (not inside the string):
<script>
</script>
I also noticed that double clicking a variablename (php) doesn't select the $ of the variable name anymore, just the name itself. In the previous version (4.3.3) it would also select the $. Personally, I don't want it to select the $ so it's fine but just mention it anyway in case it's a bug according to the specs.
Posted by: Lolo | Date: 2005-09-29 15:40 | IP: IP Logged
Sorry,
I have done a bad test.
I can confirm the problem with multihighlighter and previous javascript code.
Posted by: pspad | Date: 2005-09-29 17:40 | IP: IP Logged
You mean run compiler on the remote machine ?
You must use some software for remote access in this case.
