You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2132) beta English
Posted by: gurbao | Date: 2005-09-28 06:01 | IP: IP Logged
still cannot use Ctrl-RArrow on .sql files with @-character (local variable) using the SQL(MSSQL2000) highlighter.
Switch to SQL(Standard) highlighter it works fine.
Regards,
Posted by: Lolo | Date: 2005-09-28 09:10 | IP: IP Logged
I can confirm the problem with @ character.
It also happen with $ character in SQL (Oracle) syntax.
Posted by: DJ N-4ceR | Date: 2005-09-28 13:48 | IP: IP Logged
When I do not save the username and password, PSPad correctly asks for user/pass when connecting. Anyhow, my FTP Webserver can not keep the connection alive, so it disconnects. When saving a file or wanting to open a new from the FTP it asks newly for user/pass.
Can't it be stored in memory as long as PSPad is living as a task?
I don't want to save those data, because several ppl are using that machine.
Posted by: pspad | Date: 2005-09-28 14:43 | IP: IP Logged
Yes, its one of things what I have already in my notes
Posted by: Donius | Date: 2005-09-28 15:06 | IP: IP Logged
In Xhtml Multi Highlighter, if i use any clips in the XHTML sections, PSPad takes up 100% of cpu and goes for 5+ minutes before i killed it. PHP clips worked fine. Restarting PSPad had no effect. Very sad!
-Brendan
Posted by: pspad | Date: 2005-09-28 15:19 | IP: IP Logged
I can't confirm.
Its your clip file ok ?
Posted by: Lolo | Date: 2005-09-28 15:44 | IP: IP Logged
I can confirm the clip problem.
Open an empty file then change document syntax highlight to xhtml.
Now hit Ctrl+Space and type s
Now select samp and hit OK button
PSPad freeze
Posted by: pspad | Date: 2005-09-28 16:06 | IP: IP Logged
I am sorry, but my PSPad doesn't freeze
Can you send me your PSPad.INI ? Maybe it depends of some specific setting
Posted by: rem | Date: 2005-09-28 19:19 | IP: IP Logged
> specific setting
It's the same ini & clips files I have used before. No changes done to it. I have exactly the same behaviour as Lolo here...
Posted by: pspad | Date: 2005-09-28 20:31 | IP: IP Logged
I hope in next build it will be OK
