You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2132) beta English
Posted by: pspad | Date: 2005-09-26 23:41 | IP: IP Logged
Download link: pspad.cincura.net (1.5 MB)
this CAB archive contains PSPad.EXE and language files only. Replace existing files from last full release
Changes to 4.5.0 (2131)
Correction
Highlighter settings - buttons Al, None don't activate Apply button
Code explorer for Oracle doesn't display whole package name if name contains char $
dblclick on word doesn't select whole word if numbers were contained
pen file from internet - problem with file name if URL ends with \
Tcl/Tk comment
Java - identifiers, started with accented chars
PSPad freezes with some user highlighters (e.g. ASP)
Jan
Posted by: displeisisfactap | Date: 2005-09-27 06:34 | IP: IP Logged
Exception when going to PROJECTS -> OPEN FOLDER FILES (and in my case, no project had been set)
Still weird formating in html multi (also backspace stops working):
<?php ?>& g t ; (& g t ; without spaces)
Posted by: ;Op | Date: 2005-09-27 07:09 | IP: IP Logged
Previous freezes now work ok. Thanks Jan for this new release.
Posted by: Lolo | Date: 2005-09-27 07:39 | IP: IP Logged
Hi Jan,
All previous "bugs" seem te be fixed.
Thanks for this new release.
I am going to test it and report you problems if I find something wrong.
Posted by: PJJ | Date: 2005-09-27 08:05 | IP: IP Logged
Jan, thanks for the new release! Please remember the CSS issue, though, where hyphen is stop char for Ctrl-right arrow, as dollar sign was for xhtml multi!
As for the weird behaviour mentioned by displeisisfactap: in fact it concerns any entity, eg. &nbsp; &ndash;, written just after ?>. It is saved correctly in a file and displayed correctly on other highlighters (well, I tried PHP and CSS), but in multi.
Posted by: rem | Date: 2005-09-27 08:08 | IP: IP Logged
Since 2131 my PSPad is freezeing & crushing when I use the clips. Does enybody else had this behaviour too?
I'm using the multihighlighter on WinXP Pro SP2
Thanks.
P.S. I switched back to 2127 and everything's ok...
Post Edited (09-27-2005 10:11)
Posted by: ShiLong | Date: 2005-09-27 09:50 | IP: IP Logged
i found the error! (see last version thread)
PSPad delete my files.
Know i can reproduce the error:
Open PSPas
Save a new file anywhere.
Press STRG+D to save the file under another name.
know close the first file STRG-W (File-Close shortcut)
(notice: both files are opend in pspad!)
What happend? PSPad delete the new file on my harddisk! the error occours also, when i close the new file, the old file will be deletet!
The Workflow look at follows:
-writing classes in php
-dublicate classfiles with STRG+D the rebuild the class with new features
But know the old file is deletet. I think this is wrong!
PSPad hold the file opend, but the file doesn't longer exist! PSpad give no warnings or errors out!
I hope this is helpfully, and you can understand my little english!
Greetings,
ShiLong
Posted by: ShiLong | Date: 2005-09-27 09:51 | IP: IP Logged
"(notice: both files are opend in pspad!)" must stand on line higher! sorry, after closing one file, is only one file opend!
Posted by: ShiLong | Date: 2005-09-27 12:11 | IP: IP Logged
Another Bug:
1. Open PHP file
2. Set syntax highlighter to PHP
3. goto settings of multihighlighter
4. activate/deactivate open directly []PHP
5. save
6. cant user cursor in editor window
7. restart pspad takes no effekt
8. reset keyboard layout to default
9. restart pspad
10. now keyboard works with new highlighter settings!
Greetings,
ShiLong
Posted by: Donius | Date: 2005-09-27 21:49 | IP: IP Logged
Control-Right fixed for XHTML Multi, in php. I confirm that it still remains for the - in CSS.
Thank you for such a quick new release, Jan. You, sir, are hardcore.
-Brendan
