You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2131) beta English
Posted by: pspad | Date: 2005-09-26 08:40 | IP: IP Logged
Thomas wrote:
> Jarmo wrote:
> > And by the way, "App Paths" should go to HKLM, not HKCU.
> But writing to HKLM requires Administrator privilege and I
> think it's not good to require that.
If you don't have admin priviledges, nothings happend. I don't force you to have admin rights...
Posted by: gurbao | Date: 2005-09-26 09:30 | IP: IP Logged
Ctrl-Right does not work in .sql file on @ character (local variable).
For the time being I will revert to build 2126
regards,
Posted by: Skulstad | Date: 2005-09-26 12:36 | IP: IP Logged
>I just tried this new build out and found that the program "hangs" when I open an >ASP page. I have set up ASP as my Multihighlighter. I tried to open a SQL without >a problem.
>Had to revert back to previous beta version.
I confirm this - PSPad hangs when trying to open a SAS file linked to a user highlighter
Posted by: PJJ | Date: 2005-09-26 14:02 | IP: IP Logged
Hanging on ASP files is just a subtle way of telling you that you should convert to PHP lol
Posted by: Donius | Date: 2005-09-26 17:10 | IP: IP Logged
I have the same problem with ctrl+right in HTML Multi and XHTML Multi, Ctrl-Right stops at $, but not in PHP-only syntax, and only if i specify the php section like <?php ...code... ?>
- or -<? ...code... ?>
and *NOT* if i specify it like <?= ...code... ?>
Also, if i open php code with "<?=", double click doesn't do the new fancy action that selects the quotation marks, or the dollar sign, it just selects the text.
Thanks for new release, fabulous editor.
Posted by: pspad | Date: 2005-09-26 19:26 | IP: IP Logged
Corrected, wait for next build
