You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2131) beta English
Posted by: pspad | Date: 2005-09-25 19:21 | IP: IP Logged
Build was revoken due to serious bugs
Notes to PSPad update versions:
this CAB archive contains PSPad.EXE and language files only. Replace existing file from last full release
Changes to 4.5.0 (2127)
News
max. number of Autocomplete items was limited to 20
is possible to change Autocomplete Window size
PSPad regitered itself into register, key "App Paths". You will be able to run it without write path
PROXY password is crypted now. If you used Proxy password in program settings / Internet, you must reenter it
Correction
corrected Ctrl+Right behaviour
accented chars was marked as "bad" in JAVA highlighter
with UTF-8 code page was always CrLf EOL
PSPad shouldn't write into OPERA settings if isn't changed in Program settings
Ctrl+DblClick select text include quotes
Find in Files in binnary file closes PSPad
Program settings - some options doesn't enable "Apply" button
switch to HEX mode and back doesn't keep cursor position
exception after change HEX editor settings if bytes per column was set to 1
if clip contains empty lines, PSPad inserts previous line instead empty line
search next occurence doesn't work in some casses
user highlighter with specific settings freezes PSPad
Jan
Posted by: PJJ | Date: 2005-09-25 20:45 | IP: IP Logged
Dear Jan,
many thanks for the new build! I believe that speed of editing is now improved, which is great. On the other hand I think that "Ctrl+Right behaviour" is still a bit buggy -- when cursor is placed before a dollar sign, ctrl+right arrow works perfectly in PHP, but for some reason not in XHTML multihighlighter: it just doesn't move at all. Would you please look into it? Thanks!
Best regards,
Przemek
Posted by: PJJ | Date: 2005-09-25 21:11 | IP: IP Logged
One more thing: I just noticed that in CSS a hyphen is a stop char: when cursor is placed before it, ctrl+right arrow combination cease to work.
Przemek
Posted by: Toby | Date: 2005-09-25 21:13 | IP: IP Logged
To confirm this issue:
I can Ctrl+right with the cursor just after the $ in Xhtml multi, but not with it just before it.
Looking forward to your next great release
Posted by: jbyrne | Date: 2005-09-26 01:24 | IP: IP Logged
I just tried this new build out and found that the program "hangs" when I open an ASP page. I have set up ASP as my Multihighlighter. I tried to open a SQL without a problem.
Had to revert back to previous beta version.
Posted by: Jarmo | Date: 2005-09-26 05:53 | IP: IP Logged
I am reverting to old version too. This hangs with AutoIt3 files (.au3),. Not every file does this, but too many, so I can't use this version.
This is enough to hang PSPad. Save for example to test.au3:
$Title = "Intervocative Software DVD Profiler"
If WinExists($Title) Then
WinActivate($Title)
If WinGetState($Title) = 13 Then
Send("!{TAB}")
Sleep(500)
Send("!{TAB}")
Else
GUICreate("DVD-aktivaattori", 1, 1)
GUISetState(@SW_SHOW)
EndIf
Else
Run("C:\Program Files\InterVocative Software\DVD Profiler\dvdpro.exe")
EndIf
And by the way, "App Paths" should go to HKLM, not HKCU.
Posted by: Lolo | Date: 2005-09-26 06:59 | IP: IP Logged
I can confirm too.
Some ASP files Hang up PSPad
But I have test the text above for au3 file but it does not hang up my PSPad.
I sent you a file in order to reproduce the problem with ASP file.
Thanks and have a nice day.
Posted by: ;Op | Date: 2005-09-26 07:22 | IP: IP Logged
Also reverted to previous beta, because this one hangs on some (not all) makefile files.
Posted by: Lolo | Date: 2005-09-26 07:59 | IP: IP Logged
I have done some test from "Jarmo" example and I have found the freeze are due to "User Highlighter". Firstly, I haven't got the Jarmo's problem because I don't use Au3 files. So I have configured PSPad to support Au3 files and now it freeze.
To sum up, if you don't want PSPad to freeze, deactivate your user highlighter.
Have a nice day.
Posted by: Thomas | Date: 2005-09-26 08:15 | IP: IP Logged
But writing to HKLM requires Administrator privilege and I think it's not good to require that.
