You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2127) beta English
#51 Re: PSPad UNICODE 4.5.0 (2127) beta English
Posted by: Vinod | Date: 2005-09-21 13:05 | IP: IP Logged
Would like a new feature in the next release .While doing a search in files I would like an option to exclude certain file types using an exclusion file mask.This would be useful for example when I do a search in all files(*.*) but want to exclude (*.obj) files
#52 Online Help
Posted by: ShiLong | Date: 2005-09-22 08:47 | IP: IP Logged
the link in the online.INI file for Self HTML is wrong!
Correction:
[Deutsch]
Self HTML=http://de.selfhtml.org/
Exists a way, to define keyboard shortcuts for this help links?
Sincerely,
ShiLong
#53 Re: PSPad UNICODE 4.5.0 (2127) beta English
Posted by: ShiLong | Date: 2005-09-22 08:59 | IP: IP Logged
additional online.INI:
[PHP]
PHP Coding Standard=http://alltasks.net/code/php_coding_standard.html
WARNING! This link is a fake!
Its time to check all links... with this in mind!
Greeting,
ShiLong
#54 Re: Online Help
Posted by: pspad | Date: 2005-09-22 14:17 | IP: IP Logged
Thank you
#55 hex edit mode problem
Posted by: riechert | Date: 2005-09-22 20:01 | IP: IP Logged
When switching hex edit mode on and off the cursor changes position in the file. I think it should remain at the same relative location.
- open a text file
- position the cursor at a known location in the file
- change to HEX mode
- note the cursor is not on the same character
#56 reformat bug
Posted by: riechert | Date: 2005-09-22 20:06 | IP: IP Logged
If a try to reformat more than one paragraph at a time, the blank line between the paragraphs are lost.
- in a new text file add in several long paragraphs, separated by blank lines
- select all the text and click Ctrl-K
- note the paragraphs are reformatted correctly and each paragraph does start on a new line. But the blanks lines are lost resulting in one continuous block of text. I believe the blank lines should be kept.
- if you use Shift-Ctrl-K instead, all the paragraphs are run together instead.
#57 ARGH
Posted by: ShiLong | Date: 2005-09-23 16:33 | IP: IP Logged
WARNING
My PSPad delete laste edited file!
Report:
Windows 2000,
working on hosted network directory (Fsmiling smiley
Edited php file and visit it in iexplore parsed with linux apache webserver
total commander has opend the working directory
I close with ALT+F4 pspad and see in background, that the last edited php file was deletet in my total commander.
I have this effect at third time! But i cant reconstruct the error realy! PSPad give no warnings and are minimized to the task bar icon.
I'm sure you have questings, just mail me, and i will try to help finding the error!
Get sure to make backups of the opened files before closing pspad!
Greetings
#58 Re: PSPad UNICODE 4.5.0 (2127) beta English
Posted by: pspad | Date: 2005-09-23 18:51 | IP: IP Logged
Thank you.
If you can test it, you help me spare some time for answering over 100 other mails waiting in my mailbox.
#59 Re: ARGH
Posted by: pspad | Date: 2005-09-23 19:43 | IP: IP Logged
> pspad!
Do you have set Backup file in PSPad settings / Backup ?
Can you make step by step to simulate it ?
#60 Re: hex edit mode problem
Posted by: pspad | Date: 2005-09-24 12:22 | IP: IP Logged
Corrected in next build
