You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2127) beta English
Goto Page: 1 2 3 4 5 6 7 8 Next
Posted by: pspad | Date: 2005-09-06 16:28 | IP: IP Logged
Download link: pspad.cincura.net (1.5 MB)
Notes to PSPad update versions:
this CAB archive contains PSPad.EXE and language files only. Replace existing file from last full release
Updated 9-7-2005 due to drag/drop text problem
Changes to 4.5.0 (2126)
News
ablility drag/drop text between editor windows
added OPERA8 support in program settings / Sytem
Tcl/Tk highlighter extended of new keywords (Expect extension)
KiXtart highlighter - new keywords
new editor command ecSelWord - same functionality as Shhift+Ctrl+Down
Correction
individual TabWidth in highlighter settings
search in R/O files
bad char coding in search in files result after search in OEM or ISO files
Text differences - refresh function doesn't work, last line in first window wasn't processed
user highlighter and comment problem with #{
C code explorer - function problem
backup HEX editor files unified with standard backup system
HEX editor ignores bytes per column setting
AutoCorrection doesn't work in splitted window
PHP - select word include '$'
select block on the end of long file very slows program
Jan
Posted by: pspad | Date: 2005-09-06 16:36 | IP: IP Logged
From Thursday up to end of week I will be out of reach (some relax in nature)
Posted by: CyGho | Date: 2005-09-06 17:17 | IP: IP Logged
Thx for the update. Have a good time in the nature
Posted by: Markus | Date: 2005-09-06 20:42 | IP: IP Logged
Thanks for the quick update also from me. Now for me everything works fine.
Posted by: Lolo | Date: 2005-09-06 22:05 | IP: IP Logged
Thanks a lot for this new release but you have broken a functionality.
Select a piece of text and try to move it anywhere with drag and drop.
Nothing happens. It was ok in build 2116.
Otherwise, do you think I could be possible to add the possibilty to drag and drop text by selecting a piece of text, then drag it onto the tab of the file then PSPad will change the active file and to finish drop the selected piece of text to the desired place? (like copy and paste between to explorer in the Windows task bar)
Thanks and have a relax
Posted by: Jody | Date: 2005-09-07 00:13 | IP: IP Logged
When double clicking on text enclosed by quotes, brackets, etc the quotes and brackets are selected as well. This is not the behavior expected and only started in version 2127.
Examples:
"something"
'something'
/something/
[something]
all characters above will be selected when double clicking on the word, something.
I prefer that only the text between " ", / /, [ ] etc is selected.
Am I missing a setting or did this break when trying to fix the including $ in selection for php highlighter?
Thanks,
Posted by: Dave | Date: 2005-09-07 03:29 | IP: IP Logged
I installed this version and now my arrows keys and ENTER key is ignored in the editor. Also ignored is BACKSPACE and DELETE. I can move my cursor with the mouse, but most (maybe all) the special keys do not operate. SHIFT is OK, though. Just a heads up, I can convert back to 4.3.3 for now, I wanted to give 4.5 a try for improved worp wrapping. Oh well. Question: sftp, is it on the roadmap?
Posted by: pspad | Date: 2005-09-07 04:15 | IP: IP Logged
Problem with KeyMap.INI. Delete it or go to program settings / KeyMap, press Default and restart PSPad.
Can you tell me your OS ?
Posted by: pspad | Date: 2005-09-07 05:31 | IP: IP Logged
// are not brackets
From PSPad help (F1 in editor window):
SHIFT+LeftClick select block from cursor position
DblClick select word
CTRL+DblClick select text inside quotes
ALT+DblClick select HTML tag
CTRL+ALT+DblClick select inside any brackets
In PHP highlighter it works with no settings
Posted by: Lolo | Date: 2005-09-07 08:14 | IP: IP Logged
I agree with Jody.
Now PSPad select word with quote or single quote. In build 2116 there was not this behavior. The current behavior is like the Ctrl key is pressed during the double click.
