You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2126) beta English
Posted by: DxGx | Date: 2005-09-01 11:11 | IP: IP Logged
That's the worst part of it... it happens only sometimes and i don't understand why different files (but all php) are interpreted differently and not allways in same way
Posted by: pspad | Date: 2005-09-01 11:52 | IP: IP Logged
Are you able to send me some file where I can see it ?
Posted by: raptor | Date: 2005-09-02 04:01 | IP: IP Logged
can you add or enhance some features :
1.add view line spacing, like UltraEditor or CrimsonEditor.
2.reformat XML as good as HTML.
3.char counting when selected text more than 100 lines.
thank you.
Posted by: pspad | Date: 2005-09-02 04:24 | IP: IP Logged
You can switch on white chars - toolbutton or menu View/Special chars
> 2.reformat XML as good a HTML.
Send me some examples with description, what is wrong and should be better.
As alternative you can use for XML formating TiDy
You really need it ?
Posted by: wins | Date: 2005-09-02 04:55 | IP: IP Logged
Bug found:
In ftp, after using the pop-up "New file", and double click this newly created file will get "Cannot open file c:\DOCUME~1\...." error box.
Using XP SP2 Professional.
Posted by: raptor | Date: 2005-09-02 05:01 | IP: IP Logged
thanks for your answer
1.I means the "View|Line spacing" feature, because I want to adjust the spacing of lines to read some text(e.g. novels) comfortable.
2.The following is a part of XML formatted by "reformat HTML" function. some <tag> and </tag> is not be aligned correct(e.g. Homepage, MsgTitle...).
I will try the TiDy, thanks for your suggestion.
<Row>
<ID>
6
</ID>
<Name>
xelloss
</Name>
<Homepage>
</Homepage>
<MsgTitle>
some text
</MsgTitle>
<MsgLen>
8
</MsgLen>
<MsgRead>
9
</MsgRead>
<PostDate>
2003-09-25 10:48:44
</PostDate>
</Row>
3.Sometimes, I write some long document by PSPad, and I want to know how many chars in a paragraph - often more than 100 lines.
Thanks a lot. lol
Posted by: raptor | Date: 2005-09-02 05:04 | IP: IP Logged
sorry, It seems I used a bad emote in the previous post. -_-|||
Posted by: pspad | Date: 2005-09-02 05:05 | IP: IP Logged
> comfortable.
If you want to set Line Spacing, go to program settings / Direct edit
Change value of variable: ExtraLineSpacing=1
Posted by: raptor | Date: 2005-09-02 05:15 | IP: IP Logged
thank you very much.
Posted by: joanra | Date: 2005-09-03 00:15 | IP: IP Logged
Hello, thanks for your great program and congratulations from Spain. Ok, the last beta version is ok for me but i have a few questions:
1. Why now the shift+space autocomplete doesn't works ? With for example (in php) if + (shift+space) doesn't show nothing.
2.Is there a way to refresh the code exploration automatically? I need show the variables that i'm adding in my php code and now i need to press ctrl+shift+E every time.
3. Is there a way that auto complete (ctrl+J) just show clases (css) functions and variables (php) and doesn't show all the clips list and captured words?
Thanks for your program. Since I discovered it I uninstalled Dreamweaver and in my web studio just use PSPad+Photoshop.
Note: We will see PSPad for linux?
