You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2126) beta English
Posted by: code-breaker | Date: 2005-08-28 05:20 | IP: IP Logged
I don't know if this is new behavior or not, but the text in the MD5 window seems to be in the same language (Czech?) regardless of the language selected in program settings.
Posted by: pspad | Date: 2005-08-29 04:46 | IP: IP Logged
If you correctly unpack CAB (with subdirectories) and replace English.INI in Lang subdirectory, you have all in English.
Posted by: DxGx | Date: 2005-08-30 06:45 | IP: IP Logged
hi,
find next not working too...
Posted by: DxGx | Date: 2005-08-30 10:22 | IP: IP Logged
...and about brackets ( [], {}, () ) highlighter... it now works much slower than before for reason that i can't figure out :(.
For ex. when i trying to delete text from right near '(' or ')' bracket, like this '(|text that i want to delete)', i expecting very slow action on that.
| <- cursor position
i noticed such behaviour from first UTF version build.
My comp. 560Hz, 128MB RAM. Win XP SP2.
Any suggestion would be good.
Posted by: pspad | Date: 2005-08-31 04:52 | IP: IP Logged
> out :(.
> | <- cursor position
Send me file with description what to do.
If your computer has really only 560Hz, it must be really slow
Posted by: Thomas | Date: 2005-08-31 08:08 | IP: IP Logged
I'm using a different font then Courier New (Lucida Sans Typewriter, which is included in the Java JDK) and when I display spaces tabs and line ends, then the placeholder for spaces is not displayed at all:
hello, world
is displayed as
hello,world
It seems that PSPad is using a character code for the "space" that is only available in courier new. Other (monospaced) fonts display a very strange character which is also looking very ugly.
I usually don't like the Courier new as the the lower case L looks the same as the number 1
Thomas
Posted by: pspad | Date: 2005-08-31 09:36 | IP: IP Logged
> hello, world
> is displayed as
> hello,world
> ugly.
This character cames from UNICODE table with char hex code 05BC
Posted by: DJ N-4ceR | Date: 2005-08-31 17:45 | IP: IP Logged
Would like to have a RegExp Tester/Viewer included.
See example:
addons.mozilla.org
Cheers
DJ N-4ceR
www.n4cer.de
Posted by: pspad | Date: 2005-08-31 18:35 | IP: IP Logged
Use RegExpStudio
regexpstudio.com
Posted by: hoppfrosch | Date: 2005-09-01 05:30 | IP: IP Logged
Another good Regexp-Tester is;
weitz.de
