You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2126) beta English
Posted by: pspad | Date: 2005-08-25 19:59 | IP: IP Logged
Download link: pspad.cincura.net (1.5 MB)
Notes to PSPad update versions:
this CAB archive contains PSPad.EXE and language files only. Replace existing file from last full release
Changes to 4.5.0 (2125)
Correction
- Save as... with HEX editor file
- flickering button problem
- comment code problems
- Copy command during macro recording
Upozornění:
Somebody publish PSPad beta version on BetaNews.com server without my mind. Please stop it. I am understand, you want to help me, but I want to desision myself, if version is stable enough to be published on BetaNews or not.
Thank you.
Jan
Posted by: MarkRH | Date: 2005-08-26 00:45 | IP: IP Logged
Using either the HTML Multihighlighter or my PHP user highlighter, if I change the color of something and apply it, it seems to set the Tab width to 1 even though it's set to a width of 3 in both the highlighter and main editor settings. If I simply go into the Editor Settings (which still shows a Tab width of 3) and just click OK, then it changes back to a width of 3.
The width in the highlighters is set to 3 as well.
It seems to change the Width for everything, not just those files using the highlighter I changed the color in.
This has been occuring since build 2120 at least.
Mark H.
Mark H.
Posted by: ;Op | Date: 2005-08-26 09:01 | IP: IP Logged
When using the "Change Syntax..." function (either from "View" menu or from the status bar), if I click on <not assigned> syntax (last line) then PSPad hangs with high CPU load. This already occured in build 2120 (do known for previous builds)
Posted by: pspad | Date: 2005-08-26 09:28 | IP: IP Logged
> width of 3.
Will be OK in next build
Posted by: Rich Betschart | Date: 2005-08-26 11:49 | IP: IP Logged
The "Search in Files" does not find anything when the directory tree being searched is read only.
Rich B.
Posted by: Lolo | Date: 2005-08-26 14:32 | IP: IP Logged
> Rich B.
In fact, PSPad does not find anything simply if the file is in read only.
Posted by: pspad | Date: 2005-08-26 16:44 | IP: IP Logged
Problem found. Corrected in next build
Posted by: Nilpohc | Date: 2005-08-27 17:21 | IP: IP Logged
When working on a php file with 4.3.x version, word selection (dbl click) was also selecting the $ prefix in variables. With version 4.5.0, it seems that behaviour has changed. Is it in purpose ?
Thanks for this great software !
Benoit C.
Posted by: pspad | Date: 2005-08-27 17:56 | IP: IP Logged
4.5.0 uses new version of editor component and its different. We must tune it
Posted by: Fabricio | Date: 2005-08-27 18:57 | IP: IP Logged
It doesn't seem to work with Windows ME anyway.
When I open a file it starts a forever loop or something and I need to press CTRL+ALT+DEL to stop.
