You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2120) beta English
#61 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Branko Grbac | Date: 08/18/2005 11:00 | IP: IP Logged
See? I'm not crazy! smiling smiley
#62 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Rainer Koschnick | Date: 08/18/2005 11:35 | IP: IP Logged
Here's another odd thing...
If I open a multilanguage UTF-8 file (has German, English, Japanese, Korean, Russian, Chinese), the Korean only displays correctly if turn ON "Show spaces, tabs & line ends". With the option turned OFF the Korean displays as garbage (those small boxes which usually get displayed if your font can't display the characters).
All other languages are not affected.
#63 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: phunkydizco | Date: 08/18/2005 12:13 | IP: IP Logged
I have found a bug in the XML Highlighter.
When the highlighter is turned off the line looks like this:
<xs:schema id="ImportRollkarten" xmlns="" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
If the highlighter is turned on the line looks a little bit different:
<xs:schema id="ImportRollkarten" xmlns="="" lns:xs="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
Edit:
This happens only if the font and color of "Symbol" and "Namespace Attribate Value" are the same.
If I set one of theme to bold it works perfect.
Post Edited (08-18-2005 12:22)
#64 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: phunkydizco | Date: 08/18/2005 13:32 | IP: IP Logged
I have found a second bug in the xml highlighter.
When I change anything from "Symbol" the following line changes from this
<Element1 />
to this
<Element1 >
#65 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: pspad | Date: 08/18/2005 16:22 | IP: IP Logged
I will report it to Synedit BugTrack
#66 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: sacharja | Date: 08/21/2005 16:03 | IP: IP Logged
There is bug by using word wrap:
If you have this in a new document:
"<a(?=[^>]+href[=\'\"\\s]+http:\/\/).{1,300}?>(?=<img[^>]+src[=\'\"\\s]+http:\/
-- line break by mod --
\/)(.|\\s){0,250}?<\/a>", "<img(?=[^>]+width[=\'\"\\s]+[0-1][=\'\"\\s>])(?=[^>]
+height[=\'\"\\s]+[0-1][=\'\"\\s>]).{1,400}?>", "<img[^>]
and you use the HTML Multihighlighter for syntax highlighting the quote after <\/a>" changes to <<\/a> if you start selecting at the beginning (with word wrap on) and end selecting anywhere in the next line.
#67 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: DxGx | Date: 08/23/2005 22:05 | IP: IP Logged
heeeiiii,
where all new beta versions gone grinning smiley
lol
#68 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: sacharja | Date: 08/24/2005 02:04 | IP: IP Logged
Another problem is that selecting text and other operation with word wrap on is extermley slow :(
#69 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: pspad | Date: 08/24/2005 06:04 | IP: IP Logged
You are right if you have very long lines...
#70 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: hoppfrosch | Date: 08/24/2005 09:22 | IP: IP Logged
Bug in Search and Replace
I try to replace all spaces in a file with Carriage Return (\n).
Example input file: (Underscores represent spaces)
a_b_c_d_
e_f_g_h
i_j_k_l_m
n_o_p_q_
* PSPad only replaces a few spaces then stops (when applying "Replace all" with Regex enabled)
Result:
a
b
c
d
e_f_g_h
i_j_k_l_m
n_o_p_q_
* PSPad has a wrong count of replacements
Result:
a
b
c
d
e_f_g_h
i_j_k_l_m
n_o_p_q_
PSPad states that it has replaced the space 10 times - which is obviously wrong ...
* Applying single replacement with confirmation does only a few replacements (after confirmation of each ....) then the confirmation box disappears and PSPad pretends to be ready ...
Result:
Result:
a
b
c
d
e_f_g_h
i_j_k_l_m
n_o_p_q_
Don't know when this bug occurs first, but it definitifely occurs in Build 2120 ...
Cheers
Hoppfrosch
