You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2120) beta English
#21 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Peshkoff | Date: 08/11/2005 11:53 | IP: IP Logged
From version to version you have a this bug. Both color scheme ObjectPascal and PHP have the same extension registered *.inc and by default worked ObjectPascal.
#22 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: pspad | Date: 08/11/2005 12:44 | IP: IP Logged
Both languages uses this extension. User should decide, what language uses.
Object pascal has priority, because is prior to PHP in alphabet.
#23 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Luciano | Date: 08/11/2005 14:15 | IP: IP Logged
Ciao,
same problem on opening multiple files:
forum.pspad.com
#24 bug report?
Posted by: rejetto | Date: 08/11/2005 16:35 | IP: IP Logged
if i open the file at www.rejetto.com/temp/pspad.bug.xml
the third line is not displayed until the cursor is on it
beautiful piece of software anyway winking smiley
#25 Re: bug report?
Posted by: pspad | Date: 08/11/2005 16:56 | IP: IP Logged
Posted to Synedit bug tracer
#26 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: imeDB | Date: 08/12/2005 00:03 | IP: IP Logged
yes, that's right, unicode characters are not accepted into the box now
sametime, there are other rules already declared in earlier versions, but they were always shown in the standard english code page
#27 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: anvilsoup | Date: 08/12/2005 02:56 | IP: IP Logged
Pavel Rychetsky wrote:
> I've noticed problem with changed character spacing mentioned
> above. I've discover
> wide character spacing appears..
I have this problem also, again when I select some fonts. BUT if I zoom in and out, the problem only seems to appear with some sizes (zoom in/out with mouse scroll wheel and CTRL).
#28 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Oswald | Date: 08/12/2005 08:14 | IP: IP Logged
I've a bad behaviour in XML files with this kind of tag :
<copy file="${tech.manual.fr}" tofile="${basedir}/target/doc/fr/Tech-Manual.doc" />
I'm unable to edit correctly the end of the line :
- impossible to select the the last character.
- if backspace is pressed just before the slash character this is the slash that is deleted
- try to add the end of the tag after a space : two spaces are set and the cursor moves before the slash.
In short, it's very strange...
#29 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Oswald | Date: 08/12/2005 08:20 | IP: IP Logged
The toolbar button to reload the active file in the text diff doesn't work.
#30 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: pspad | Date: 08/12/2005 16:12 | IP: IP Logged
> doesn't work.
Yes, I know, I found this problem yesterday sad smiley
