You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2120) beta English
#11 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: tdusem | Date: 08/08/2005 15:03 | IP: IP Logged
I have an update on the wider character spacing. It happens when using a syntax hilighter. Non-highlited spacing is tha same as the 4.3.3 version
#12 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: pspad | Date: 08/08/2005 15:28 | IP: IP Logged
What you exactly mean ?
#13 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: tdusem | Date: 08/08/2005 16:20 | IP: IP Logged
If I maximize pspad, my display show 197 characters wide by 74 lines high without having a hilighter selected. If I select a syntax highlighter, the display chages to 175 characters wide by 74 lines high. The characters are spread out with biggger spaces between them.
If I try the same experiment on v 4.3.3, the display is 197 characters wide in both syntax highlited and non hilighted mode.
#14 Re: causes crash
Posted by: pspad | Date: 08/08/2005 19:31 | IP: IP Logged
anvilsoup wrote:
> Wow a Beta! I tried loading one of my html files (which I
> created with an older version of PSPad) and I found that the
> following line causes it to crash.
<script>
function checkData() {
</script>
> Actually even typing in <script causes it to crash before you
> type >.
Please write exactly what highlighter is set, where I must type to crash PSPad. I can't simulate it sad smiley
#15 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Mathieu Pellerin | Date: 08/09/2005 02:57 | IP: IP Logged
pspad wrote:
>Mathieu Pellerin wrote:
>> I noticed PHP syntax misses one thing
>> print <<<END
>> blabla
>> blabla
>> END;
>> PSPad will never close the print function where it should (at
>> END;)
>What you mean "never close the print function" ???
<<<KEYWORD and KEYWORD; are not considered as a opening and closing quotes, it mixes up the syntax highlighting
#16 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Oswald | Date: 08/09/2005 16:08 | IP: IP Logged
The problem with the Visual Basic highlighter and code explorer and the word "class" in a line is still not solved :
Sub MySub1
Dim className
className = object.Class.Name
End Sub
Sub MySub2
End Sub
the variable "className" is truncated too...
Great enhancements in 4.5 anyway !
Keep the good work !
#17 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: pspad | Date: 08/09/2005 17:05 | IP: IP Logged
Please send me your code to mail as atachment. Code you sent into forum works OK for me. Maybe you have some strange chars into source or something...
And add your PSPad.INI to I will be able to test it with your configuration.
#18 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: imeDB | Date: 08/10/2005 21:40 | IP: IP Logged
hi, i tried using the Spell Sttings (CTRL+F7) from Settings menu, but it does not accept unicode chars
10x
#19 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: pspad | Date: 08/11/2005 05:26 | IP: IP Logged
> 10x
You mean you can't enter chars in dialog boxes ?
#20 Re: PSPad UNICODE 4.5.0 (2120) beta English
Posted by: Pavel Rychetsky | Date: 08/11/2005 10:25 | IP: IP Logged
I've noticed problem with changed character spacing mentioned above. I've discover
wide character spacing appears when:
- syntax highlighting is turned on AND
- other font than default Courier New is selected (e.g. Lucida Console or Fixedsys) AND
- there is any item in selected highlighter emphasized by Bold font; this is not true in Multihiglighter case - problem stays although I disabled Bold mephasizing at all items at all highlighters
I remember similar problem appeared in non-Unicode version long time ago.
