You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2120) beta English
Goto Page: 1 2 3 4 5 6 7 8 Next
Posted by: pspad | Date: 08/07/2005 16:19 | IP: IP Logged
Download link: pspad.cincura.net (1.5 MB)
Notes to PSPad update versions:
this CAB archive contains PSPad.EXE and language files only. Replace existing file from last full release
Changes to 4.5.0 (2119)
News
- in Sort function is possible enter LOCALE for sorting (available on WinNT only)
Correction
- added missing functionality comment/uncomment block
- internally rewrited huge of code (optimalization, UNICODE support)
- dblclick on word with accented chars with active highlighting
Posted by: DeliciousMonkey | Date: 08/08/2005 09:44 | IP: IP Logged
Error opening it
AppName: pspad.exe AppVer: 4.5.0.2120 ModName: kernel32.dll
ModVer: 5.1.2600.1560 Offset: 000138b2
DM.
Posted by: pspad | Date: 08/08/2005 10:13 | IP: IP Logged
DeliciousMonkey wrote:
> Error opening it
And what should I say ?
Only "it works", because I have reaction from other people.
Try download or decompress it again and clear browser cache
Posted by: DxGx | Date: 08/08/2005 12:56 | IP: IP Logged
hi,
i expecting long load time and sometimes application hang, on big files (like PHP.DEF).
In past versions there was everything OK. Waiting for fix or suggestion;)
anyway great tool!!!
Posted by: anvilsoup | Date: 08/08/2005 13:58 | IP: IP Logged
Wow a Beta! I tried loading one of my html files (which I created with an older version of PSPad) and I found that the following line causes it to crash.
<script>
function checkData() {
</script>
Actually even typing in <script causes it to crash before you type >.
Posted by: anvilsoup | Date: 08/08/2005 14:00 | IP: IP Logged
When I click the HTML reformat button, lines get over-written randomly. This is even with word wrap set to off.
Posted by: pspad | Date: 08/08/2005 14:37 | IP: IP Logged
> suggestion;)
I have no problem with load tens MB files (over 50MB exported registry with PSPad start up to 3s)
I have no responses from other users to have problems with "normal" big files (I don't mean hundreds MB files)
Delete PSCache.BIN (if exists)
Backup your PSPad.INI and run PSpad without it
Posted by: pspad | Date: 08/08/2005 15:03 | IP: IP Logged
Send me concrete source and description what is wrong
Posted by: DxGx | Date: 08/08/2005 16:33 | IP: IP Logged
THANKS!! It worked!!
again GREAT editor!!! expecting other cool enhancements ;)
Posted by: tdusem | Date: 08/08/2005 16:33 | IP: IP Logged
Is there a reason that the character spacing in the edit window changed? This version has more space between the characters. I just looked odd to me.
