You are here: PSPad forum > Developer forum - new builds > Re: PSPad UNICODE 4.5.0 alpha (2119) English
Posted by: Joe Belmaati | Date: 2005-08-06 11:17 | IP: IP Logged
Thank you very much
Posted by: Mathieu Pellerin | Date: 2005-08-07 04:44 | IP: IP Logged
I noticed PHP syntax misses one thing
print <<<END
blabla
blabla
END;
PSPad will never close the print function where it should (at END;)
Posted by: pspad | Date: 2005-08-07 05:51 | IP: IP Logged
> print <<<END
> blabla
> blabla
> END;
> END;)
What you mean "never close the print function" ???
Posted by: Jume | Date: 2005-08-07 07:03 | IP: IP Logged
its a way to defining strings, basically, its like a block, you define the "END" block, then you put any text in there, then you close the block putting the name, "END" in this case
its not necesarily the function "print", but anything else, another example would be:
$my_string = <<<MYSTR
This is a string,
and i'm able to write it
in multiple lines or wathever
i like it.
And so, i will end my string putting the name defined before.
MYSTR;
not sure about the meaning of "not closing the function" either, the only thing i see its that the contents are not colored like a string (maybe thats the problem?), but the code after is colored correctly
hope that helps...
Post Edited (08-07-2005 09:08)
Posted by: V. | Date: 2005-09-29 05:48 | IP: IP Logged
When I upgraded the PSPad from the latest stable version to beta and reopened it, all the files that were opened in previous session were empty and only the way to make PSPad read them again was reloading them. Is there any way to fix it?
Posted by: pspad | Date: 2005-09-29 08:20 | IP: IP Logged
Why you use very old Alpha version ? Download a last 4.5.0 build
