You are here: PSPad forum > Developer forum - new builds > Re: [Direct edit] Special settings explanation
#1 [Direct edit] Special settings explanation
Posted by: Stefan | Date: 08/22/2004 16:04 | IP: IP Logged
Posted by: Stefan | First at Date: 08/22/2004 16:04
Since PSPad 4.3.1 beta (1989), Date: 07-20-2004
there are new features, available only through [Special settings]
Edit them with "Settings\Program Settings... [Direct edit] -button
on the down side of the settings dialog box.
See next post for a long list of all "Special settings" features
Edited 13 time(s). Last edit at 02/05/2011 14:29 by pspad.
#2 Re: [Direct edit] Special settings explanation
Posted by: Stefan | Date: 04/18/2007 16:23 | IP: IP Logged
there are new features, available only through PSPad.ini in [Special settings] section
related thread:
http://pspad.com/forum/read.php?f=6&i=623&t=623
You can edit this settings direct in PSPad:
goto "Settings\Program Settings... "
and press the [Direct edit] button
on the left down side of the settings dialog box.
Because i always don´t overwrite my PSPad.ini
i think i don´t get automatically those new "[Special settings]" entries.
But that's wrong! Here is an workaround from Jan:
Go to program settings and save settings.
New items will be created with default values.
Current entries till build
PSPad unicode 4.5.4 (2335)
Date: 11/23/2008, with default settings:
[Special settings]
LeftToPreviousLine=0
ContinueComment=1
OpenAllReadOnly=0
DontChangeFileAttribs=0
AutoDetectBinary=1
DragImgAlt=1
DragImgTitle=1
DragImgBorder=1
TextClipsIfHLOff=0
CheckDocChanges=1
ExtraLineSpacing=1
CtrScrollIfSelected=0
OldMainIcon=0
HLOnUpToSize=250000
GutterClickInclLF=0
MaxRecent???= (e.g. MaxRecentFiles=15 MaxRecentHistory=15)
WordWrapEnabled=0
MainFileInPreview=0
SimpleFileTabs=0
OldSpecialChars=0
F1InEditor=1
ShowHint=1
MultiHLUpToSize=20000
TransparencyLevel=255
OpenFileSizeLimit=250000000
SessionCloseFiles=0
RightDockWidth=200
CodeExplorerLimit=200000
CheckDeleted=off
Explanations:
LeftToPreviousLine=
1 means: go from pos 1 to end of previous line even with "[x] Scroll past EOL" enabled.
0 means: you can´t use left arrow button, if you are on line begin and you have "[x] Scroll past EOL" enabled.
implemented since:
related thread:
Author: pspad Date: 09-28-2004 14:34
If you enable "Settings\Program Settings...\Editor behaviour\[x] Scroll past EOL"
you can´t press left arrow button, if you are on line begin,
to moves the cursor to the end of previous line.
With this option you even can !
ContinueComment=
1 means:
0 means:
implemented since:
related thread:
http://pspad.com/forum/read.php?f=4&i=1007&t=1006 Chybne odradkovani.
Author: pspad Date: 09-28-2004 14:39
if you are e.g. in C++ language (or PHP, Java, ...) try start comment: /* and then press Enter
If ContinueComment=1, automatically is generated * on next line, aligned under previous
OpenAllReadOnly=
1 means YES, open all files in "read only mode" by default
0 means NO, enable only "read only mode" if file is read only, or enable r/o in PSPad file by file
implemented since:
related thread:
http://pspad.com/forum/read.php?f=2&i=3387&t=3386 ReadOnly as Default parameter
http://pspad.com/forum/read.php?f=2&i=3754&t=3592 Why is PSPad changing Unix permissions?
1 means: disables any file attribute manipulation, this overwrites "Program Settings"
0 means: allow PSPad to manipulate files attribute like PSPad want, or as you checked in "Program Settings"
implemented since:
related thread:
AutoDetectBinary=
1 means YES, PSPad should dectect and open binary files in his Hex editor by default
0 means NO. PSPad should open files always as "text file", even binary files (open binarys through context menu by yourself)
implemented since build 2001, Date: 08-19-2004
related thread:
http://pspad.com/forum/read.php?f=6&i=478&t=478 beta 1975
http://pspad.com/forum/read.php?f=4&i=897&t=897 1975 opens *.doc as HEX
http://pspad.com/forum/read.php?f=2&i=2312&t=2312 Feature Request: Automatic HEX-mode
http://pspad.com/forum/read.php?f=6&i=766&t=766 beta 2001
set content of tag for Drag/Drop image
if you d&d an image into a HTML file, then you can choose with this settings the tag entries:
DragImgAlt=1 means create an Alt=" " entry in the image tag
DragImgAlt=0 means don´t create an Alt=" " entry
DragImgTitle=1 means create an Title=" " entry in the image tag
DragImgTitle=0 means don´t create an Title=" " entry
DragImgBorder=1 means create an Border=" " entry in the image tag
DragImgBorder=0 means don´t create an Border=" " entry
e.g.
[img]F:/PSPad/Lang/Croatian.bmp[/img]alt="Croatian.bmp, 0 kB" title="Croatian" border="0" height="14" width="17">
implemented since build 4.3.2 (2009) 09-19-2004
TextClipsIfHLOff=
my guessing was this...
TextClipsIfHLOff=0 means, if Highlighter is off, non clip file is used
TextClipsIfHLOff=1 means, if Highlighter is off, TEXT clip file is used
implemented since build 4.3.2 (2017) 17.Okt. 2004
from Jan: TextClipsIfHLOff [Special settings] - if Highlighter is off, TEXT clip file is used
see also http://forum.pspad.com/read.php?f=2&i=8280&t=8280
CheckDocChanges (for currently opened files)
-enables/disables document change detection confirmation
for reload document(s) changed by other program you can make for all changed documents
CheckDocChanges=1 means dedect document change by other program an update open file
CheckDocChanges=0 means don´t dedect this and keep the old file state as you opened bevor
implemented since build 4.3.2 beta (2022) , Date: 11-07-2004
related thread:
Externally modified file warnings
ExtraLineSpacing=n
you can set line spacing with ExtraLineSpacing parameter
( 'n' is a integer value, dafault is =1 )
Try e.g. ExtraLineSpacing=20 to see you get more room between every sinle line
implemented since build 4.3.2 beta (2025) , Date: 11-21-2004
related thread:
CtrScrollIfSelected=1
If set to "1", window will always scroll with Ctrl key
implemented since build 4.3.2 beta (2039) , Date: 12-19-2004
related thread:
OldMainIcon=1 => set old icon in forms
Old Icon for desktop link (and other link) is still part of PSPad.exe,
you can simply change it by changing link propertys.
implemented since build 4.3.2 (2042) Date: 06.01.2005
related thread: here
HLOnUpToSize=x
Value 'x' sets max. file size limit for auto switch on highlight syntax.
Disable highlighter for big files, e.g. for greater than 250kB
HLOnUpToSize=250000
It mean if file size is less then value, highlighter will be activated automatically. (only if enabled in highlighter settings of course)
If the file size bigger than value 'x' no syntax is highlighted.
You can set value 'x' to 0, if you never want automatically syntax highlighting.
You can click on tool bar button and switch on highlighting if you need it.
You can set this value e.g. to 2 000 000 000 if you has the time to wait for bigger files to load with syntax highlighting winking smiley
implemented since build 4.3.3 beta (2047) Date: 08.02.2005
related thread: http://forum.pspad.com/read.php?f=2&i=5529&t=5529
GutterClickInclLF=1
means, if you click on left gutter,
the hole line is selected including the line feed
implemented since build 4.3.3 beta (2071) Date: 08.Mai.2005
related thread: http://forum.pspad.com/read.php?f=2&i=6764&t=6764
MaxRecent???=
is possible to set max. number of recent files
and other history items (search, Command window, Google, ...)
implemented since 4.3.3 beta (2073) Date: 05-18-2005
related thread: http://forum.pspad.com/read.php?f=2&i=7031&t=6982
WordWrapEnabled=0 Default state is 0 - word wrap is disabled.
WordWrapEnabled=1 If you want actual buggy word wrap, you must enable it.
implemented since 4.3.3 beta (2079) Date: 06-02-2005
related thread: http://forum.pspad.com/read.php?f=2&i=7118&t=7110
there are many many many about buggy word wrap in the forum, please search
MainFileInPreview=
switch if internal HTML preview shows MainFile or actual file
implemented since 4.3.3 beta (2081)Date: 06-05-2005
SimpleFileTabs=0
=0 switch off owner draw for file tabs - problems with 64bit OS
=1 enable
implemented since PSPad UNICODE 4.5.0 (2125) beta 24.Aug-05
OldSpecialChars=
Set value to 1 if you use non-unicode fonts, e.g. FixedSys
PSPad uses chars above base ASCII table (> #255) to display spaces and tabs.
If you use non-unicode font, theses chars are missing
and PSPad shows you e.g. an black square.
This option force PSPad to use base ascii table chars for it.
see http://forum.pspad.com/read.php?f=2&i=11817&t=11733
implemented since PSPad unicode 4.5.1 (2185) 02-23-2006
F1InEditor=
- you can switch off "Help on F1" in the editor Window,
and use the F1 shortcut key for your own purposes.
implemented since PSPad unicode 4.5.1 (2199) English 03-29-2006 / 29-Mrz-2006
ShowHint=
ShowHint=0 - disable program hints
implemented since PSPad unicode 4.5.2 (2237) English Date: 09/03/2006
MultiHLUpToSize=
to determine max. file size in bytes for multihighlighter
implemented since PSPad unicode 4.5.3 (2259) English Date: 03/03/2007
TransparencyLevel=
TransparencyLevel (0..255)
allows you set transparency for main window.
Lower value means higher transparency.
implemented since PSPad unicode 4.5.3 (2293) Date: 11/13/2007
related thread: PSpad's transparency
SessionCloseFiles=0
RightDockWidth=200
Sets max. file length in bytes.
Files over this value ain't parsed automatically in Code explorer
and you have to start parsing with Code explorer Refresh button
Implemented with PSPad unicode 4.5.4 (2335) Date: 11/23/2008
CheckDeleted=off
option for detection deleted files
Default is off.
Implemented with PSPad unicode 4.5.5 (2390) Date: 05/30/2010
Post Edited (02-24-2006 16:50)
Edited 10 time(s). Last edit at 05/31/2010 20:36 by Stefan.
