You are here: PSPad forum > Translation > Re: Dutch
Re: Dutch
#1 Dutch
Posted by: Lode | Date: 09/19/2007 01:38 | IP: IP Logged
In the Dutch translation two strings are not very well translated:
aPrintPrev_Caption=Voorbeeld afdrukken
aPrintPrev_Hint=Voorbeeld afdrukken
Would be better like this:
aPrintPrev_Caption=Afdruk voorbeeld
aPrintPrev_Hint=Afdruk voorbeeld
This is the difference between someling like "print a preview" and "preview the print".
--Lode
#2 Re: Dutch
Posted by: Stefan | Date: 09/19/2007 07:39 | IP: IP Logged
Lode:
This is the difference between something like
--Lode
Hi Lode,
i see no "Dutch" language file, only an "Nederlands.ini"
Did you mean this?
And this "Nederlands.ini" have to be updated in general.
There are a lot of string to be translated into dutch.
In this "Nederlands.ini" you will find the author of this language ini.
Would you please contact him and ask him to update the ini
or did you want to update the ini?
Send then the new "Nederlands.ini" or "Dutch.ini" to Support at PSPad.
Thanks
greets, Stefan
image (pleased user since 1722)
inofficial FAQs + Infos + Special Settings
