You are here: PSPad forum > Bug report / Hlášení chyb > CTRL+space code helper closing
Posted by: rvilmos | Date: 2018-06-30 11:18 | IP: IP Logged
The code helper is open (CTRL+space).
When I press ESC to hide, it is not close. What is the right way to close?!
But if the Code Explorer is visible, it is closing!
Posted by: pspad | Date: 2018-06-30 11:38 | IP: IP Logged
ESC is correct way how to close it.
Tested on my PSpad and ESC closes both Ctrl+J or Ctrl+Space window.
Didn't you changes shortcuts? Maybe you assign ESC to any function. Look into %APPData%\KeyMap.ini
