You are here: PSPad forum > Bug report / Hlášení chyb > "Usage tracking" checkbox bug 5.0.0 (277)
#1 "Usage tracking" checkbox bug 5.0.0 (277)
Posted by: GuestU | Date: 2018-06-06 11:40 | IP: IP Logged
In the program settings (part 2) I uncheck the "Anonymous application usage tracking" option and click "Apply". I close PSPad, then open it again, go to program settings (part2) again. Now, the "Anonymous application usage tracking" setting has not remained disabled after disabling that option (it is still in the default state of enabled). Windows 10
#2 Re: "Usage tracking" checkbox bug 5.0.0 (277)
Posted by: pspad | Date: 2018-06-06 11:46 | IP: IP Logged
It's my fault. This option has no meaning. It worked in developer builds only, in the full version isn't tracking code included (conditional compiling) but the checkbox remains there.
Embarcadero stopped analytics servers, so it wont be neither in the developer builds.
It's disadvantage, cause it helps me catch situation when users has any problem - program exceptions was fired.
Thank you let me know, I will remove this checkbox from settings.
#3 Re: "Usage tracking" checkbox bug 5.0.0 (277)
Posted by: GuestU | Date: 2018-06-06 11:53 | IP: IP Logged
Sure, thanks for clarifying.
