You are here: PSPad forum > Bug report / Hlášení chyb > PSPad crashing only in non-admin user mode
Posted by: Stratadrake | Date: 2018-05-26 03:09 | IP: IP Logged
Okay, this looks like a weird one ... I can't use Find/Replace in PSPad at all without it crashing. The error seems self-explanatory, but...
Quote:Exception description:Cannot create file "C:\Program Files (x86)\PSPad editor\Recent.INI". Access is denied.
Exception class: EFCreateError
Exception address: 004C332C
Stack list, generated 5/25/2018 7:49:44 PM
[004C3327] System.Classes.TFileStream.Create + $BF
[00409E07] System.@ClassCreate + $7
[004C3244] System.Classes.TFileStream.Create + $20
[004BF5B1] System.Classes.TStrings.SaveToFile + $19
[0050B41F] System.IniFiles.TMemIniFile.UpdateFile + $43
[007B8B62] uFindReplace.TfFindReplace.FormCloseQuery (Line 358, "uFindReplace.pas" + 13) + $4
[00633369] Vcl.Forms.TCustomForm.CloseQuery + $55
[0063339B] Vcl.Forms.TCustomForm.CloseModal + $23
[00633A2B] Vcl.Forms.TCustomForm.ShowModal + $1DB
[007B7CEA] uFindReplace.ShowFindReplace (Line 116, "uFindReplace.pas" + 10) + $4
[0098889B] uMain.TfPSPad.aFindExecute (Line 6154, "uMain.pas" + 6) + $4
[00996B4C] uMain.TfPSPad.ActionListExecute (Line 11199, "uMain.pas" + 11) + $7
[0052F0E4] System.Actions.TContainedActionList.ExecuteAction + $70
[00409B56] System.@CallDynaInst + $6
[00531EBD] Vcl.ActnList.TCustomAction.Execute + $69
[004D45A3] System.Classes.TBasicActionLink.Execute + $13
[0064E763] Vcl.Menus.TMenuItem.Click + $93
[006503EF] Vcl.Menus.DoClick + $EF
[006504DB] Vcl.Menus.TMenu.IsShortCut + $87
[0063401D] Vcl.Forms.TCustomForm.IsShortCut + $4D
[0063841E] Vcl.Forms.TApplication.IsShortCut + $4E
[00637952] Vcl.Forms.TApplication.WndProc + $482
[004D549C] System.Classes.StdWndProc + $14
[00633FB0] Vcl.Forms.DispatchShortCut + $5C
[0065D8DC] Vcl.Controls.SendAppMessage + $18
[00669C65] Vcl.Controls.TWinControl.IsMenuKey + $7D
[00669C9D] Vcl.Controls.TWinControl.CNKeyDown + $1D
[00662C06] Vcl.Controls.TControl.WndProc + $2BE
[006677EB] Vcl.Controls.TWinControl.WndProc + $63B
[006F1C02] SynEdit.TCustomSynEdit.WndProc (Line 6351, "SynEdit.pas" + 22) + $4
[00666DB8] Vcl.Controls.TWinControl.MainWndProc + $2C
[00638328] Vcl.Forms.TApplication.IsKeyMsg + $84
[00638293] Vcl.Forms.TApplication.IsMDIMsg + $3F
[006385D7] Vcl.Forms.TApplication.ProcessMessage + $CF
[0063863E] Vcl.Forms.TApplication.HandleMessage + $A
[00638971] Vcl.Forms.TApplication.Run + $C9
[009C1A72] PSPad.PSPad (Line 95, "PSPad.dpr" + 39) + $7
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.0 (277)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 3FAB,
Processor: AMD, AMD A8-7410 APU with AMD Radeon R5 Graphics , 2200 MHz MMX
Display : 1366x768 pixels, 32 bpp
Active Controls Hierarchy:
TButton "bOK"
TfFindReplace "fFindReplace"
I generally use my system in normal user (non-admin) mode, with a second (local-only) user account set up for admin access rights. PSPad was installed with admin access, but (again) I run it at normal user level (non-admin).
The exception can occur almost anywhere (including, ironically, when exiting PSPad itself), but I first discovered it when attempting to do a Find/Replace operation. The exception DOES NOT occur if I am running PSPad as an admin.
Posted by: vbr | Date: 2018-05-26 23:23 | IP: IP Logged
it looks like, PSPad is installed to the protected system folder C:\Program Files (x86)\ ... but is configured to have its ini files etc. in the main program folder (in single user environment) - this fails without admin mode, as writing there is disallowed (e.g. recently used search terms like in this case).
To fix this, You can either enable the Multi user environment
Settings: System integration: [x] Multi User Environment
(it might need admin privileges to change the setting)
These files are then stored in user profile folders
Alternatively, You can move the program to some custom not-protected folder, like D:\myprograms\PSPad\
then the single user environment should work too.
regards,
Posted by: Stratadrake | Date: 2018-05-27 19:21 | IP: IP Logged
vbr:To fix this, You can either enable the Multi user environment
That worked. Glad to know it was probably my fault during the installation.
Now let me do a quick PSPad re-install just to verify something....
...Okay, no further problems.
Previously, in addition to the above error, I was also getting standard file security warnings when trying to run PSPad which I couldn't seem to disable (even WITH admin verification!). It also blocked shortcuts (e.g. desktop or Start menu links) from working, and when re-running the installer sometimes the 'single user' option was available and other times disabled and it didn't feel consistent why. But a delete of the PSPad folder and a clean re-installation (sidenote: the "single user" option was correctly disabled) appears to have resolved everything.
