You are here: PSPad forum > Bug report / Hlášení chyb > Build 261 - 277 have same project tree highlight bug.
Posted by: MarkRH | Date: 2018-05-23 23:23 | IP: IP Logged
Not sure which forum to put this as it involves various versions.
Here is what version 251 looks like when clicking an item in the project tree which is the last version that worked:
All versions I've tried including 277 do this:
Sometime I can't see any highlight at all.
Using this in Windows 7 Pro 64bit with a Windows Classic Theme. When trying different versions, simply changed the pspad.exe file. Everything else came from the 271 version that I unzipped.
Mark H.
Posted by: pspad | Date: 2018-05-24 09:13 | IP: IP Logged
Current 5 version is build 277. It fixes your problem
Posted by: MarkRH | Date: 2018-05-24 22:06 | IP: IP Logged
Build 277 does the same thing:
Put the 251 Executable in its place and it looks like:
Mark H.
Posted by: pspad | Date: 2018-05-25 03:32 | IP: IP Logged
Are you sure it's a build 277 on the first pic? Longer lines in project tree was problem in previous version
Posted by: MarkRH | Date: 2018-05-25 23:06 | IP: IP Logged
Yeah, it's the 277 build. I downloaded the portable version again and extracted out pspad.exe. It does the same thing.
Here's the file details.
This is on Windows 7 Pro 64bit.
Mark H.
Posted by: czapek | Date: 2018-07-05 21:59 | IP: IP Logged
I have similar problem.
When item is highlighted the text become invisible
system: Win10 x64
PSPad 5.0.0.277
samouk - kdo je víc?
Win10 x64
