You are here: PSPad forum > Bug report / Hlášení chyb > Re: code explorer for xHarbour/ftFiveWin - PSPad 5.0
Posted by: Jacenty_K | Date: 2018-05-16 09:26 | IP: IP Logged
After upgrade PDPad to 5.0 - do not work Code Explorer for ftFoxPro and ftFiveWin. Where is the definition file for languages dbase, Clipper, Harbour, xHarbour - in prior version this worked ok.
Regards
Jacek
Posted by: pspad | Date: 2018-05-16 10:32 | IP: IP Logged
Code explorer is internal. What does it mean "doesn't work"? It shows file type isn't supported or doesn't show content?
Can you send me some source sample to support mail?
Posted by: Andreas | Date: 2018-05-17 09:18 | IP: IP Logged
BTW While you are working on the code explorer. PHP Methods (functions) of Classes still do not open automatically. You can test it with some of these classes (php files).
github.com
https:// github.com/contao/core/tree/3.5/system/modules/core/library/Contao
This methods are the main thing developers like to examine and therefore should be opened by default.
Edited 1 time(s). Last edit at 2018-05-17 09:19 by Andreas.
Posted by: Jacenty_K | Date: 2018-05-21 06:45 | IP: IP Logged
pspad:HelloCode explorer is internal. What does it mean "doesn't work"? It shows file type isn't supported or doesn't show content?
Some times this function don't show all functions or los some classes, on version 4 all works ok, I don't see this problems.
Is in future create code explorer for a xHarbour and a Harbour? ftFiveWin is more closely.
Regards
Jacek
Posted by: pspad | Date: 2018-05-21 07:09 | IP: IP Logged
Again. I need some source codes with comments what should be in code explorer.
When you will send me it, I will be able to create code explorer.
