You are here: PSPad forum > Bug report / Hlášení chyb > code explorer for xHarbour/ftFiveWin - PSPad 5.0
#1 code explorer for xHarbour/ftFiveWin - PSPad 5.0
Posted by: Jacenty_K | Date: 05/16/2018 09:26 | IP: IP Logged
After upgrade PDPad to 5.0 - do not work Code Explorer for ftFoxPro and ftFiveWin. Where is the definition file for languages dbase, Clipper, Harbour, xHarbour - in prior version this worked ok.
Regards
Jacek
#2 Re: code explorer for xHarbour/ftFiveWin - PSPad 5.0
Posted by: pspad | Date: 05/16/2018 10:32 | IP: IP Logged
Code explorer is internal. What does it mean "doesn't work"? It shows file type isn't supported or doesn't show content?
Can you send me some source sample to support mail?
#3 Re: code explorer for xHarbour/ftFiveWin - PSPad 5.0
Posted by: Andreas | Date: 05/17/2018 09:18 | IP: IP Logged
BTW While you are working on the code explorer. PHP Methods (functions) of Classes still do not open automatically. You can test it with some of these classes (php files).
github.com
https:// github.com/contao/core/tree/3.5/system/modules/core/library/Contao
This methods are the main thing developers like to examine and therefore should be opened by default.
Edited 1 time(s). Last edit at 05/17/2018 09:19 by Andreas.
#4 Re: code explorer for xHarbour/ftFiveWin - PSPad 5.0
Posted by: Jacenty_K | Date: 05/21/2018 06:45 | IP: IP Logged
Some times this function don't show all functions or los some classes, on version 4 all works ok, I don't see this problems.
Is in future create code explorer for a xHarbour and a Harbour? ftFiveWin is more closely.
Regards
Jacek
#5 Re: code explorer for xHarbour/ftFiveWin - PSPad 5.0
Posted by: pspad | Date: 05/21/2018 07:09 | IP: IP Logged
Again. I need some source codes with comments what should be in code explorer.
When you will send me it, I will be able to create code explorer.
