You are here: PSPad forum > Bug report / Hlášení chyb > application error in build 251
#1 application error in build 251
Posted by: Gorlash | Date: 12/11/2017 21:43 | IP: IP Logged
Access violation at address in module 'pspad.exe'.
Read of address .
I had 10 files open, none of them very large.
Windows 7 64bit
Error log:
Exception address:
Stack list, generated 12/11/2017 13:40:52.
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : C:\pspad\pspad.exe 5.0.0 (251)
System : Windows 7 Professional x64, Version: 6.1, Build: 1DB1, Service Pack 1
Processor: Intel, Intel(R) Xeon(R) CPU W3670 @ 3.20GHz, 3200 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_4"
Edited 1 time(s). Last edit at 12/22/2017 10:46 by Stefan.
