You are here: PSPad forum > Bug report / Hlášení chyb > Re: build 251 - bookmarks messed up now
#1 build 251 - bookmarks messed up now
Posted by: Gorlash | Date: 12/08/2017 18:16 | IP: IP Logged
I use bookmarks *extensively* in my work; for some reason, this build is messing with them. At a minimum, bookmarks 2 and 3 seem to be goofed up; setting one clears the other... I've never seen this behavior before!!
#2 Re: build 251 - bookmarks messed up now
Posted by: pspad | Date: 12/08/2017 19:03 | IP: IP Logged
I used bookmarsk too. Can you prepare some instruction for simulation?
#3 Re: build 251 - bookmarks messed up now
Posted by: Gorlash | Date: 12/11/2017 16:03 | IP: IP Logged
Well, damn... when I open up *one* file and test this, it works fine.
But it *was* happening last week; I had to quit the program and switch to another editor. Maybe it was because I had many files open, I don't know.
Anyway, if I see it again, what if anything should I look at?
#4 Re: build 251 - bookmarks messed up now
Posted by: pspad | Date: 12/11/2017 16:20 | IP: IP Logged
Nothing special. I need to repeat it to find a problem.
#5 Re: build 251 - bookmarks messed up now
Posted by: Gorlash | Date: 12/11/2017 20:59 | IP: IP Logged
Bah... now it is not happening even with lots of files open...
Cannot repeat... if it happens again, I'll write down more specific info.
nevermind for now.
