You are here: PSPad forum > Bug report / Hlášení chyb > FTP TLS/SSL, PROT P not working, server supports it
#1 FTP TLS/SSL, PROT P not working, server supports it
Posted by: dr | Date: 10/09/2017 23:06 | IP: IP Logged
This happens with two independent servers, "inmotion" and "a small orange". I get the same logs. PROT C works, but PROT P does not. I know PROT P is supported by both servers, since Total Commander works properly while sending PROT P.
PSPad 4.6.2 (2750)
SSL library: OpenSSL 1.0.2k 26 Jan 2017
Connecting to: xxxxx.com
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 9 of 150 allowed.
220-Local time is now 18:57. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 30 minutes of inactivity.
AUTH TLS
234 AUTH TLS OK.
USER xxxxx
331 User xxxxx OK. Password required
PASS xxxxx
230 OK. Current restricted directory is /
PBSZ 0
200 PBSZ=0
PROT P
200 Data protection level set to "private"
TYPE I
200 TYPE is now 8-bit binary
STRU F
200 F OK
MODE S
200 S OK
REST 0
350 Restarting at 0
REST 1
350 Restarting at 1
REST 0
350 Restarting at 0
Certificate: /OU=Domain Control Validated/OU=COMODO SSL Wildcard/CN=*.inmotionhosting.com
FEAT
211-Extensions supported:
EPRT
IDLE
MDTM
SIZE
MFMT
REST STREAM
MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
MLSD
AUTH TLS
PBSZ
PROT
UTF8
TVFS
ESTA
PASV
EPSV
SPSV
ESTP
211 End.
CWD /
250 OK. Current directory is /
TYPE A
200 TYPE is now ASCII
PASV
227 Entering Passive Mode (209,182,213,120,133,233)
MLSD
150 Accepted data connection
SYST
TYPE A
PASV
#2 Re: FTP TLS/SSL, PROT P not working, server supports it
Posted by: pspad | Date: 10/10/2017 05:15 | IP: IP Logged
Thank you for report. I have to make some FTP server with Prot P support to test it.
#3 Re: FTP TLS/SSL, PROT P not working, server supports it
Posted by: dr | Date: 10/10/2017 14:00 | IP: IP Logged
I can give you access, no problem, just contact me on my email address.
#4 Re: FTP TLS/SSL, PROT P not working, server supports it
Posted by: pspad | Date: 10/10/2017 17:59 | IP: IP Logged
OK. Just now I am stuck with my job work. When I will stare some time, I will let you know for test account. It will be better to test it on real environment.
