You are here: PSPad forum > Bug report / Hlášení chyb > Clipboard error (copy from another program to clipboard)
#1 Clipboard error (copy from another program to clipboard)
Posted by: marjuanm | Date: 09/20/2017 20:55 | IP: IP Logged
Hi, greetings from México!
I use PSPad (4.6.2) (great program), I activated the clipboard viewer on PSPad and then copy a string to clipboard from another program, but in this moment PSPad crash (only time), attach a debug log, greetings again and thanks.
Exception class:
Exception address:
Stack list, generated 17/09/2017 09:59:20 p.m.
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : C:\trabajos\programas\pspad\PSPad.exe 4.6.2 (2750)
System : Windows 7 Professional x64, Version: 6.1, Build: 1DB0,
Processor: Intel, Intel(R) Pentium(R) CPU B940 @ 2.00GHz, 2000 MHz MMX
Display : 1366x768 pixels, 32 bpp
Active Controls Hierarchy:
TTntListBox ""
TfClipMon ""
TPanel ""
TfPSPad ""
Edited 1 time(s). Last edit at 10/30/2017 13:25 by Stefan.
