You are here: PSPad forum > Bug report / Hlášení chyb > Re: will not register proper extensions
Posted by: Edgar | Date: 2017-08-04 22:22 | IP: IP Logged
PSPad 4.6.1 (2730) 7/4/16 (it sure would be nice if every About dialog put this information on the clipboard <grin>
An application creates files with the extension:
.E++FP
PSPad crashes after rejecting the "+" as valid input to the text box.
Steps to reproduce:
1) pick Menu item "Settings> Program Settings…>
2) pick "Registered File types" button
3) in the "Type:" text field enter: ".e+"
at this point the "+" is filtered out
4) tried to shifted "=" key
filtered out
5) finally settle on ".eppfp" and change the application's code to match
6) click "Add New"
PSPad crashes
Run the application and create a new file with the ".eppfp" extension. Open that files folder and note that it has the PSPad icon; double click on the icon and PSPad opens the file appropriately (in reality it is a text file).
-Ed
Posted by: pspad | Date: 2017-08-09 12:29 | IP: IP Logged
In the next build I allow enter "+" in extension in program settings / registered types and User highlighter definition dialogs
