You are here: PSPad forum > Bug report / Hlášení chyb > Re: File explorer - not resizable list of files
Posted by: betadex | Date: 2017-05-25 08:25 | IP: IP Logged
In 2 last builds I noticed following the in File explorer. There is directory tree at the top and a file list at the bottom working strangely. The file list window is not resizable. It only shows a few files like 6 files, but Directory tree always fills the most of vertical window height.
It worked fine before. It is a new bug which appeared very recently.
I usually need opposite behavior. I need to see longer list of files and it is fine for me to see a few directories only.
Edited 1 time(s). Last edit at 2017-05-25 08:26 by betadex.
Posted by: pspad | Date: 2017-05-25 08:39 | IP: IP Logged
File explorer is resizable. You can drag/drop middle line and change parts.
PSPad remembers size of parts. You see it as you change it last time.
Posted by: betadex | Date: 2017-05-25 09:19 | IP: IP Logged
It is how it worked before, but now, I cannot drag the middle line. That's the problem. I have no clue, what I do wrongly, but the mouse never shows me the "resize" pointer, so I cannot drag it.
I can nicely resize the file explorer to left and right, also I can resize entire explorer window at the bottom, like make is bigger or smaller, but it is not possible to resize this middle line.
Posted by: pspad | Date: 2017-05-25 10:06 | IP: IP Logged
I just tested it now. I am able to drag line in the File explorer betwwen upper and lower part of window.
OK.
Go to program settings / Direct edit button
Click on the config in the left list
Find FileExplorerFileHeight and set it e.g. to 500
Confirm and restart PSPad
Posted by: betadex | Date: 2017-05-25 10:39 | IP: IP Logged
OK, I did it. Thank you very much.
The size of file list changed and the middle line (file list) is resizable again.
I have no clue, what happened before, but it is working now.
Thank you.
