You are here: PSPad forum > Bug report / Hlášení chyb > Re: Access violation while closing a file
#1 Access violation while closing a file
Posted by: Y-Phil | Date: 05/16/2017 09:04 | IP: IP Logged
Hi
9 times out of 10, I'm getting an access violation while closing a window.
Typical example:
1. starting PSPad V5.0.0 (207)
it opens with an empty text file
2. menu: file -> close
3. result:
Exception class:
Exception address:
Stack list, generated 16/05/2017 11:01:48
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : N:\Infocyp\PSPad\PSPad.exe 5.0.0 (207)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 3839,
Processor: Intel, Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz, 4000 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
I'v tried to reinstall PSPad from scratch: same effect.
Thanks in advance for any help.
Edited 1 time(s). Last edit at 05/18/2017 14:30 by Stefan.
#2 Re: Access violation while closing a file
Posted by: pspad | Date: 05/16/2017 09:07 | IP: IP Logged
I am very sorry for caused problems. I fixed this bug yesterday and update will be available this weekend.
#3 Re: Access violation while closing a file
Posted by: vbr | Date: 05/16/2017 16:58 | IP: IP Logged
Y-Phil:
Hi
Typical example:
3. result:
if it is the same bug, I'm just experiencing, you may try a workaround, until it is fixed - just leave at least one tab (e.g. an empty one) open, while working with pspad and then just close the whole program. For me, the error appear on closing the last tab individually; closing the program with at least one tab seems ok.
hth,
#4 Re: Access violation while closing a file
Posted by: Y-Phil | Date: 05/17/2017 07:19 | IP: IP Logged
vbr:
hth,
Thanks for the hint smiling smiley
#5 Re: Access violation while closing a file
Posted by: pspad | Date: 05/17/2017 07:45 | IP: IP Logged
I hope it's fixed in todays build 211
