You are here: PSPad forum > Bug report / Hlášení chyb > Re: UTF-8 BOM only
Re: UTF-8 BOM only
#1 UTF-8 BOM only
Posted by: Vany | Date: 05/09/2017 17:29 | IP: IP Logged
If just and only the UTF-8 BOM mark is present in the file (it means it is precisely 3 bytes long), the PSPad editor doesn't detect it like UTF-8 file and displays these strange characters with default codepage even if the UTF-8 is chosen in the Format menu.
(PSPad unicode 5.0.0 (243), W7p x64 cs)
Edited 1 time(s). Last edit at 05/09/2017 17:33 by Vany.
#2 Re: UTF-8 BOM only
Posted by: pspad | Date: 05/09/2017 18:37 | IP: IP Logged
Use PSpad 5 from developer forum. It's near ready to be released and it has much better code page handling.
#3 Re: UTF-8 BOM only
Posted by: Vany | Date: 07/31/2017 20:39 | IP: IP Logged
I'm using version 5.0.0 (235), but still the same
#4 Re: UTF-8 BOM only
Posted by: pspad | Date: 08/01/2017 06:59 | IP: IP Logged
Do you want to say you have UTF-8 document with BOM and PSPad doesn't detect it as UTF-8?
It can be caused for only one reason. Your document isn't correct, it means it contains non UTF-8 chars in it. Decoding as UTF-8 will cause lost of non UTF-8 chars. It's typically export of the database.
Can you send me any example? Than smaller than better.
#5 Re: UTF-8 BOM only
Posted by: Vany | Date: 08/01/2017 11:13 | IP: IP Logged
As I wrote in the topmost message - if it is completely empty, but has the BOM present, so the file is 3 bytes in length, then it is not detected as an empty UTF-8 file, but PSPad opens it as standard text file with these bytes shown with ANSI Central European (1250) CP.
Code Page Autodetect is ON.
Edited 2 time(s). Last edit at 08/01/2017 11:20 by Vany.
#6 Re: UTF-8 BOM only
Posted by: pspad | Date: 08/09/2017 14:44 | IP: IP Logged
Empty file with UTF-8 encoding was special case.
I tested if file size > 0B and after loading editor is empty. In this case I open file as ANSI. I will handle files with BOM only.
#7 Re: UTF-8 BOM only
Posted by: Vany | Date: 09/05/2017 17:30 | IP: IP Logged
thanks for correction, from 241 it is okay now
Editor PSPad - freeware editor, © 2001 - 2017 Jan Fiala
