You are here: PSPad forum > Bug report / Hlášení chyb > Exception in latest (beta) version
#1 Exception in latest (beta) version
Posted by: viplex | Date: 04/20/2017 07:56 | IP: IP Logged
Mailing was impossible due to "Index out of range" error when clicking button.
Exception description:
Access violation at address x in module 'PSPad.exe'. Read of address x.
Exception class: x
Exception address: x
Stack list, generated 20/04/2017 09:52:59
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had x files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.0 (182)
System : Windows 10 Professional x64, Version: 10.0, Build: 295A,
Processor: AMD, AMD Athlon(tm) II X4 640 Processor, 3020 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TfChildEdit "x"
Edited 3 time(s). Last edit at 04/20/2017 08:30 by Stefan.
