You are here: PSPad forum > Bug report / Hlášení chyb > Re: Current line color
Posted by: Anonymous User | Date: 2017-02-22 09:30 | IP: IP Logged
.txt-file
PSPad version 2745
Win7 Enterprise x64
Hi. When you have a line of text that stretches outside the right side of the screen (i.e. the line is too long to display in its entirety), and you press ctrl+u (uppercase) or ctrl+l (lowercase), the line loses its 'current line color' until I go to another line and back.
It's rather annoying as I use these functions quite a lot. Can you fix it?
This behaviour has been around for as long as I remember (> 10 years), so I suspect it to relate to all PSPad versions.
Edited 1 time(s). Last edit at 2017-02-22 09:30 by Skulstad.
Posted by: pspad | Date: 2017-02-22 10:33 | IP: IP Logged
When text is not selected, you UPPERCASE or Lowercase whole document.
I am not able to simulate it.
Is WordWrap on?
Do you have selected some text when you uppercase it?
Can you write me some step by step?
Posted by: Anonymous User | Date: 2017-02-22 11:05 | IP: IP Logged
Yes, I have highlighted the current line, thus uppercase/lowercase works on this line only.
Word wrap is OFF.
Edited 1 time(s). Last edit at 2017-02-22 11:05 by Skulstad.
Posted by: pspad | Date: 2017-02-22 11:52 | IP: IP Logged
OK. I have some text with long lines.
I change PSPad window width to Line oversize window width.
I select one line (e.g. clicking on the gutter before line)
I will uppercase selected line (Ctrl+Alt+U)
And? Line stays selected. What's wrong?
Posted by: Anonymous User | Date: 2017-02-22 12:56 | IP: IP Logged
Thereafter, when you use ctrl+u (uppercase) or ctrl+l (lowercase), the line loses its 'current line color' until I go to another line and back.
Edited 1 time(s). Last edit at 2017-02-22 12:56 by Skulstad.
Posted by: pspad | Date: 2017-02-22 13:07 | IP: IP Logged
It stays selected for me with selection color, so I don't see current line color.
Posted by: Andreas | Date: 2017-02-22 14:23 | IP: IP Logged
It also works for me as pspad says.
Win 10
PSPad 4.6.2 2745
Edited 1 time(s). Last edit at 2017-02-22 14:23 by Andreas.
Posted by: Anonymous User | Date: 2017-02-23 12:41 | IP: IP Logged
Hi. I am sorry. Maybe I'm doing something wrong (obviously). Can you please figure out what - I can't find it out.
Posted by: pspad | Date: 2017-02-23 13:01 | IP: IP Logged
I tried yesterday to simulate it, but unsuccessfully.
Can you record video? Or write steps with comments what do you see?
Posted by: Andreas | Date: 2017-02-23 13:26 | IP: IP Logged
I also tested it again with a clean portable installation and can not reproduce it.
