You are here: PSPad forum > Bug report / Hlášení chyb > Re: 4.6.1 (2730) up to 4.6.2 (2745) freeze after long time usage
Posted by: mgutt | Date: 2017-02-16 11:27 | IP: IP Logged
I don't know why this happens. I had this several years ago. Now I'm using Windows 10 for a longer time and PSPad accidentally begins to freeze again.
Sometimes it freezes after some minutes and sometimes after several hours or after pc wake-up.
I do not have any anti-virus software installed (except of the windows defender that is part of windows 10).
I don't think I changed many things in the last weeks. The only thing I can remember of is switching between LIST and MLSD mode and raising the FTP timeout because of this problem:
forum.pspad.com
And I added some new ftp accounts as well.
Ah, and I had a wrong encoded file on my host, changed it between UTF-8 and ISO and finally I had some days later the problem that UTF-16 was selected?! But after I changed it back to UTF-8 the problem was solved.
Now I will test a little bit around. At first I deselected most of the Highlighters, so only these are left:
The next tests:
- leave pspad open without ftp connection and without any opened files
- leave pspad open with open files but ftp disconnected
Posted by: mgutt | Date: 2017-02-20 10:42 | IP: IP Logged
It seems to be a problem with the ftp connection. In all my tests it does not freeze as long I'm disconnected from the ftp server.
Posted by: pspad | Date: 2017-02-20 13:43 | IP: IP Logged
And I guess there is problem with FTP with SSL/TLS support.
Posted by: mgutt | Date: 2017-02-21 06:39 | IP: IP Logged
Ok, I will change one account to non ssl and test further.
Screenshot:
Edited 1 time(s). Last edit at 2017-02-21 06:41 by mgutt.
Posted by: pspad | Date: 2017-02-21 09:25 | IP: IP Logged
Problem with TSL and FTP is solved, wait for next build please
Posted by: mgutt | Date: 2017-02-22 16:47 | IP: IP Logged
Ok fine. Finally I can verify that is only with TLS FTP accounts. Cause after disabling it, it never freezed again.
