You are here: PSPad forum > Bug report / Hlášení chyb > Re: build 2743 - no longer portable ?
#1 build 2743 - no longer portable ?
Posted by: Gorlash | Date: 01/28/2017 17:24 | IP: IP Logged
I've been using build 2743 at work, and it is working fine.
Unfortunately, at home it is *not* working as expected.
So I zipped up my pspad directory from work, unzipped it into a clean c:\pspad directory at home, but it is still working wrong here;
In particular, I notice the following changes:
> the editor is using some other color scheme, rather than the one that I use
> Ctrl-X no longer deletes current line, if no text is highlighted.
I tried to fix the latter issue by using KeyMap to change the settings for Edit:Cut, but that no longer works.
Have I somehow ended up with a non-portable version or something?
Otherwise, how do I fix this?
#2 Re: build 2743 - no longer portable ?
Posted by: pspad | Date: 01/28/2017 18:37 | IP: IP Logged
Hello, there is no change, PSpad stays portable.
Check Program settings / System integration in your work computer.
If there is multiuser environment checked, it means PSPad config files are stored in user profile folder, not in the PSPad folder.
To fix it, change this option and copy files from %AppData%\PSPad (your work computer) into PSPad folder
#3 Re: build 2743 - no longer portable ?
Posted by: Gorlash | Date: 01/29/2017 13:34 | IP: IP Logged
AHA!!! Yes, all fixed! Thank you...
I'll add this note to my pspad notes.
