You are here: PSPad forum > Bug report / Hlášení chyb > PHP formatting errors when ?> enclosed within quotes
#1 PHP formatting errors when ?> enclosed within quotes
Posted by: doctorlai | Date: 09/29/2016 20:00 | IP: IP Logged
The workaround is to split ?> into ?" . ">
#2 Re: PHP formatting errors when ?> enclosed within quotes
Posted by: doctorlai | Date: 09/29/2016 20:01 | IP: IP Logged
When I said formatting, I meant the syntax coloring/highlighting...as you can see in the picture... the highlighting/coloring after ?> is messed up.
#3 Re: PHP formatting errors when ?> enclosed within quotes
Posted by: carbonize | Date: 10/01/2016 16:50 | IP: IP Logged
Exceptionally well reported issue that occurs when using multihighlighter. Switch to PHP highlighter.
Carbonize
