You are here: PSPad forum > Bug report / Hlášení chyb > Bug in syntax highlighting for "shell"
#1 Bug in syntax highlighting for "shell"
Posted by: rovf | Date: 2016-04-26 14:17 | IP: IP Logged
When the highlighter is set to "Unix Shell Script", the shell command
true
is highlighted as a reservied word / builtin, but the command
false
is not. Either both should be highlighted or none (I suggest the former).
Ronald Fischer (Germany)
#2 Re: Bug in syntax highlighting for "shell"
Posted by: pspad | Date: 2016-04-28 06:04 | IP: IP Logged
Both will be highlighted in the next build
