You are here: PSPad forum > Bug report / Hlášení chyb > Re: Problems with charset
Posted by: toto | Date: 2016-02-04 06:36 | IP: IP Logged
I just upgrated to version 4.6 (2700) from 4.5.9 (2600) where I got problems with the charset.
After the Upgrate I opened a PHP file with FTP And saved it over ftp. I don't changed anything at the charset. After upload all € signs are resplaced with ? signs.
When I downgrated I found another issue ;)
4.5.9 working
HTML code: content="text/html; charset=iso-8859-1"
PSPad: Format=ISO 8859-2
-> € works in the browser
4.5.9 not working
HTML code: content="text/html; charset=iso-8859-2"
-> € invisible in the browser
4.6 not working
HTML code: content="text/html; charset=iso-8859-1" or iso-8859-2
-> instead of € a ? is visible in the browser
When I was switching the Format (UTF-8, OEM) in PSPad to find the failure and saving over FTP, PSPad changed all my € signs into ? in my PHP files A warning like : "not all signs could be saved in this format" will be fine ;) (if this is not another failure )
greetings
Thorsten
Posted by: pspad | Date: 2016-02-04 06:53 | IP: IP Logged
When you open your file, do you see chars correctly, include '€' ?
When you open your file, check code page on the statusbar.
In your FTP connection settings, is there binary transfer type? If not, FTP server manipulates with text file content.
Posted by: Freeman | Date: 2016-02-06 23:16 | IP: IP Logged
ISO-8859-1 nor ISO-8859-2 doesn't contain the euro sign. Use ISO-8859-15 or Windows-1252 instead.
Posted by: toto | Date: 2016-02-07 08:56 | IP: IP Logged
both are not available in PSPad ;) But good to know, I will try it
Edit: Only Windows-1252 AND iso-8859-1 works (PSPad 4.5.9)
Edited 1 time(s). Last edit at 2016-02-07 09:03 by toto.
Posted by: toto | Date: 2016-02-07 09:53 | IP: IP Logged
pspad:When you open your file, do you see chars correctly, include '€' ?
in PSPad 4.5.9 AND 4.6 yes
pspad:When you open your file, check code page on the statusbar.
4.5.9 AND 4.6 iso-8859-2
pspad:In your FTP connection settings, is there binary transfer type? If not, FTP server manipulates with text file content.
yes binary
tried another update to 4.6
always ? insted of € with all charsets in HTML + PSPad
Then I switches to tuf-8 in HTML and PSPad and it works.
Like Freeman wrote it's ok when it's not working ;) Perhabs iso-8859-1 works because of a workaround of Chrome???
greetings
Thorsten
Posted by: toto | Date: 2016-02-07 10:19 | IP: IP Logged
OK UTF-8 is fine but the text in my Database (MySQL) is another format (PHPMyAdmin says UTF-8 Grrrrrr) so I downgrated to 4.5.9 and changed all back. I think this is my problem
NEW PROBLEM:
I changed the PHP File in 4.6 to iso-8859-2 and saved it with FTP. All Fine in 4.6. Downgrade to 4.5.9 and all € are switched to ? !!! 4.5.9 say iso-8859-2.
I think 4.6 saves in a differtend charset then 4.5.9 ...
