You are here: PSPad forum > Bug report / Hlášení chyb > Re: HTML Preview Web Server partially working.
Posted by: johnbentley | Date: 2016-01-05 04:27 | IP: IP Logged
Bug Description:
Executing the command [HTML > HTML Preview Web Server] does not display the loaded html page, served from a settings specified web server location, on first opening PSPad. It will correctly load the page, and serve it from the specified web server, if the user visits [Settings > Program Settings ...] then subsequently runs [HTML > HTML Preview Web Server].
Steps to reproduce the bug.
1. Create a web page at C:\Users\UserName\Documents\Webroot\index.html
2. Open PSPad. Settings > Program Settings > Web Server. Fill out as follows
Server: localhost:8080
Document Root: C:\Users\UserName\Documents\Webroot
[Assuming a web server correctly configured to run at that location]
3. Close PSPad.
4. Open PSPad. Load C:\Users\UserName\Documents\Webroot\index.html into PSPad. HTML > HTML Preview Web Server. Observe the wrong Url is returned "http:///index.html" and the error message displayed is "This page can't be displayed".
5. Close the HTML Page Preview window. PSPad > Settings > Program Settings. Press Cancel (no need to change any value in the Program Settings Window).
6. HTML > HTML Preview Web Server. Observe the correct url is displayed "http://localhost:8080/index.html". You may need to hit the "Go to Page" command to load the page. Observe the page is correctly displayed.
Running:
Windows 10 Pro
PSPAD 4.6.0 (2700)
Posted by: pspad | Date: 2016-01-05 06:08 | IP: IP Logged
If you use project, check project settings. It's possible you have some stored settings in your project and project settings has priority before common settings
Posted by: johnbentley | Date: 2016-01-07 14:20 | IP: IP Logged
I'm not using a project.
Can you (or someone else) reproduce the bug?
Posted by: pspad | Date: 2016-01-07 14:51 | IP: IP Logged
I will test it. Sorry, I am exhausted in my work just now and lack time for the rest as PSPad.
Posted by: johnbentley | Date: 2016-01-08 03:07 | IP: IP Logged
No worries at all. Take care of yourself first. This is just a bug to put on the list to deal with whenever you are in a relaxed state of freedom.
