You are here: PSPad forum > Bug report / Hlášení chyb > Re: Real Tabs setting not apply on startup
Posted by: Beck Yang | Date: 2015-10-14 14:24 | IP: IP Logged
version 4.6.0(2700)
Steps to reproduce:
1.Open menu item "Settings" -> "Program Settings..." -> "Editor (part2)", check "Real Tabs" then press "OK".
2.Close PSPad process and open again
3.Press "TAB" key, but the content string are space chars, not a tab char.
4.Open menu item "Settings" -> "Program Settings...", press "OK".
(The "Real Tabs" is checked in "Editor (part2)")
5.Press "TAB" key, the content string add a tab char.
The "Real Tabs" works after change setting, but it does not work after restart PSPad. Please verify, thanks.
Posted by: pspad | Date: 2015-10-14 14:31 | IP: IP Logged
I found a problem for TXT files if URL highlighter was enabled. This problem is fixed and fix will be available in the next developer build up to end of this week.
Posted by: Beck Yang | Date: 2015-10-16 08:36 | IP: IP Logged
I just test v4.6.1 (2703)
The problem is fixed. Thank you.
