You are here: PSPad forum > Bug report / Hlášení chyb > Re: Help file contents is scrambled
Posted by: Phant | Date: 2015-10-12 09:52 | IP: IP Logged
Hi!
The contents of the help file of version 4.6.0 (2700) has random characters being spread all over the text, thus it's hard to read or is sometimes even unusable. Could it be that you are using a trial version of your help authoring tool?
Greetings
Phant
P.S.: Thanks for the new version of PSPad.
Posted by: pspad | Date: 2015-10-12 10:20 | IP: IP Logged
Can you tell me which topic is wrong or send any screenshot?
Posted by: pspad | Date: 2015-10-12 10:34 | IP: IP Logged
You are right. The problem is joined with Windows 10 upgrade. I reregistered Help authjoring tool and it should be OK again. I will reupload setup packages.
You can download fixed help file here:
www.dropbox.com
Posted by: Phant | Date: 2015-10-13 10:24 | IP: IP Logged
Thanks! The help contents is showing up properly now.
Greetings
Phant
P.S.: Although I have enabled e-mail notification, I did not get any for this thread (even looked through spam folder). Is the notification function timed in any way (only every 24 hours or so)? There don't seem to be any further setting for this.
Edited 1 time(s). Last edit at 2015-10-13 10:25 by Phant.
Posted by: pspad | Date: 2015-10-13 11:09 | IP: IP Logged
I reuploaded packages for download with fixed help.
Regarding to your problem, there must be something wrong in forum engine. I will look at it, but I need to find time first.
