You are here: PSPad forum > Bug report / Hlášení chyb > Display bug on comment of sql file
#1 Display bug on comment of sql file
Posted by: Calson | Date: 2015-09-03 09:05 | IP: IP Logged
Dear Support staff,
I am using pspad 4.59 in Windows 7 and windows 10. It has a display problem in comment section of sql file. e.g. in editing sql files, right hand side of B in '-- tableB' has display problem.
-- tableB
select * from tableB;
Hopefully it could be fixed soon.
BTW, this version is much better than previous version with a lot of enhancement on icons.
Thanks so much for your work and effort.
lc
smiling smiley
#2 Re: Display bug on comment of sql file
Posted by: pspad | Date: 2015-09-03 10:01 | IP: IP Logged
Visit PSPad forum and download the latest build 4.6.0 from PSPad
developer forum: www.pspad.com
Replace existing files with content of archive.
This build contains fix of your problem
