You are here: PSPad forum > Bug report / Hlášení chyb > Re: Minor ui problems
Posted by: viplex | Date: 2015-09-02 09:25 | IP: IP Logged
I have two things that seem a bit odd, screenshots attached.
1. Sometimes when I open pspad it shows an error, I often work with ftp, maybe it tries to reopen some file there.
2. The tab background is black, is it possible to make that like the rest of the ui?
Both are nothing critical, but of course it would be great if that could be solved.
Edit: I am using windows 8.1 64 bit
Best Regards
Edited 1 time(s). Last edit at 2015-09-02 09:27 by viplex.
Posted by: pspad | Date: 2015-09-02 09:42 | IP: IP Logged
It means there is some file in the .\script subfolder what isn't script.
Check it pleae
Posted by: pspad | Date: 2015-09-02 09:43 | IP: IP Logged
Regards to black tab background. Which PSPad version do you use?
Posted by: viplex | Date: 2015-09-02 14:17 | IP: IP Logged
thank you very much. I had a readme file in scripts, strange..
Regarding the second one..
I am using 4.5.9, sometimes it's only a line that is black but it becomes bigger if I switch between tabs and buttons in ui settings.
Best Regards
Posted by: pspad | Date: 2015-09-02 14:48 | IP: IP Logged
Download the latest 4.6.0 build from the PSPad developer forum. This build fixes your problem
